Old 01-10-2005, 02:13 PM
chris15706 chris15706 is offline
cant switch vent
The air always comes out of my top vents. I cant switch it to the floor or anything else. Any ideas?
Old 01-10-2005, 02:21 PM
kenwood guy's Avatar
kenwood guy kenwood guy is offline
Send a message via Yahoo to kenwood guy
Re: cant switch vent
put on the air conditoner switch it then see what happens
Simon R
2001 Silverado W/T 4.3
124,000
Old 01-10-2005, 02:24 PM
I can switch from ac to heat but everything blows on my face no matter what.
Old 01-10-2005, 02:28 PM
whoops I mean turn on the air condioner while its on switch the vent and see what happends
Simon R
124,000
Old 01-10-2005, 04:24 PM
It doesnt matter what i do. It still only comes out the front vents. I was thinking maybee a hose was disconnected but i looked under there and everything seems to be fine.
Old 01-10-2005, 04:59 PM
Fractured1 Fractured1 is offline
Check the vacuum ball mounted on your hood, make sure the lines are attached and not cracked..
Old 01-10-2005, 06:27 PM
Im sure i could find it if i looked long enough but what does it look like? Its one of those things i have never messed with. If everything checks out ok there, any other suggestions?
Old 01-10-2005, 10:16 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
yeah, anything ever been spilled into the vent such as candy or pop (soda for all of you non michiganders)
Old 01-11-2005, 12:07 AM
Well im from Arkansas and we call everything coke. Doesnt make any sense does it... Anyways, i havent spilled anything down there. Im wondering if maybee there is a switch or fuse under the hood that has gone out. I just figured that there was someone else out there with a similar problem. Any input helps...
Old 01-11-2005, 10:01 AM
Mikado14 Mikado14 is offline
Do you think you could post the year of your vehicle? Not every Blazer uses vacuum to control the vents.
Old 01-11-2005, 01:34 PM
2000 s-10 2.2 4cyl
Old 01-11-2005, 02:34 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Vaccum leak, check all vacuum lines going to the control panel all the way to the vacum ball in the engine bay.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-03-2005, 01:35 AM
PEPSIGIRL PEPSIGIRL is offline
Send a message via Yahoo to PEPSIGIRL
Hi I have a 99 Lumina and mine does the same almost except it blows under the dash by the floorboard and it seems to change when i brake??
Old 05-03-2005, 01:49 AM
BlazerLT's Avatar
AF -Advisor
Vacuum leak.
You brakes run off of vacuum too.
You need to trace all vacuum lines and check for leaks and splits.
