Old 01-10-2005, 02:05 PM
GSX-RACER GSX-RACER is offline
6bolt in a 2g eclipse
Does anybody know if I would have problems if I would put a 6bolt engine into a 2g eclipse.
Old 01-10-2005, 02:10 PM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
SEARCH. This gets asked like clockwork every 2 weeks.
http://www.magnusmotorsports.com/article_1g2g.htm
There you go
1999 Eclipse Spyder GST-Race
-DSM Link,Injen Intake,Spearco FMIC,HKS SSQ B.O.V.,Apex TurboTimer,Greddy Evo Exh 3",660 injectors,Walbro 255 fuel pump,B&M Fuel Pressure Reg,Heads Ported & Polished,Momo Short Shifter Clutch Masters lightened Flywheel,C.M.Kevlar Clutch,Quaife LSD,Autometer Boost & A/F Gauge, EvoIII B16g Turbo,HKS 272/272 cams & HKS Cam Gears,Crower Valve Springs & Rods,Power Pulley Kit,100 shot Zex Nitrous
Old 01-10-2005, 03:18 PM
CBURKE's Avatar
CBURKE CBURKE is offline
Re: 6bolt in a 2g eclipse
Yes.......Yes.......Yes.........Yes, and oyeah YES!!!
ummm let's see 4g63T and a 4g63T. Yep it will fit.
Old 01-10-2005, 04:13 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
would i have to get a new dsm link for the 6bolt swap
Old 01-10-2005, 05:48 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
no.
Old 01-11-2005, 07:59 AM
kjewer1 kjewer1 is offline
AF - Advisor
DSMlink is highly recomended though. I ran my swap with an AFC and the "Baro Wire mod" for the first year or two, but once I stepped up to the 50 trim I was no longer comfortable lying to the ECU about airflow AND baro presure. But its your call.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-11-2005, 01:00 PM
JoeWagon's Avatar
Banned
I think he has 2g dsmlink and wants to know if it will work with a 6 bolt swap, in which case I've never heard of a problem. There are even features in DSMlink to use the 6 bolt better.
Old 01-12-2005, 08:21 AM
AF - Advisor
Ah, I see. I'm a dumbass. Yes, DSMlink absolutely makes running a 6 bolt better. To rephrase, I wouldnt run a 6 bolt again without it.
Kevin Jewer
