Old 03-09-2002, 04:36 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
EG SiR Guage HELP!!
Anyone who has knowledge of installing an SiR guage into a USDM EG please help (Sorry for the poor quality pics, all I have is a webcam)
LEFT PLUG
RIGHT PLUG
GREEN PLUG (CENTER)
When I have the left and right plugged in, everything seems to work EXCEPT my signals. Is this GREEN PLUG needed for my signals to work? Because the the plug from my car is different from the green socket of the SiR guage?
Also anyone have problems with fitting the JDM guage in? I took a quick try and it didn't seem like it fit properly. The JDM guage is a little thicker.
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 03-09-2002, 09:49 PM
OK ... I got the signal to work now but the guage doesn't fit in properly. I have the cluster from a sedan so is there a difference in size between the sedan and hatchback/coupe cluster??
Old 03-10-2002, 01:14 AM
JayFidizzy's Avatar
JayFidizzy JayFidizzy is offline
Banned
Send a message via AIM to JayFidizzy
even though this is for indiglo gauges maybe it can help.
http://www.seas.ucla.edu/~cheston/In...loinstall.html
Old 03-10-2002, 02:27 AM
No that didn't help but thanks anyways. I need to know if the SiR guage is supposed to bolt right it because it seems to hit the back and I cannot match the sides up the the original bracket ... anyone??
Old 03-11-2002, 10:51 AM
liquid8 liquid8 is offline
Send a message via AIM to liquid8
i'm pretty sure that the coupe and sedan gauges are different. you might need to modify it. bu i'm not sure.
Old 03-11-2002, 01:24 PM
madtownhonda's Avatar
madtownhonda madtownhonda is offline
Send a message via AIM to madtownhonda
SiR sedan gauges are the same only have a door open indicator
96 EX DOHC VTEC
Old 03-11-2002, 02:06 PM
OK I have a CX ... but when I put the cluster in it seems to hit the back of the dash ... Am I putting it in wrong or is the dash on a CX not as deep as an EX or Si???
Old 03-11-2002, 10:56 PM
same exact dash...lets see a picture of the front
96 EX DOHC VTEC
Old 03-11-2002, 10:59 PM
I don't have a digicam but I got a webcam and the cluster is sitting in my dash at the moment ...
But it's the exact same as this guage:
Old 03-12-2002, 07:38 AM
GTRsi GTRsi is offline
Send a message via AIM to GTRsi
trust me they are all the same guage clusters. Make sure all your connections are plugged in properly. And the guys above are right the only diff bewteen the clusters is the sedans have the door open indacator (sp). when I installed mine it took a little wiggel here and there to make it fit. BUT BE GENTLE.
Killer Ninja's are not trained, they are born!
Old 03-12-2002, 12:19 PM
Thanks ... I'll give a gentle wiggle
Old 03-13-2002, 04:24 PM
emadboy200's Avatar
emadboy200 emadboy200 is offline
Send a message via AIM to emadboy200 Send a message via Yahoo to emadboy200
I have the same gauges in my car and I can tell you from first hand experience that the sedan cluster is bigger than the hatchback one.
Old 03-13-2002, 04:39 PM
what the hell...because I have seen the exact same 4 door gauge cluster that fit and plugged up to a 92 Si hatch
96 EX DOHC VTEC
Old 03-13-2002, 04:52 PM
emadboy200's Avatar
don't get me wrong the sedan clusters do fit, but they are slightly thicker than the hatch ones. Plus the hatchback cluster has an open trunk indicator light right next to the check engine light. I will try to take a picture of my guage and post it on here for you guys.
Old 03-13-2002, 05:10 PM
Interesting ... I thought the sedan ones were a little thicker ... Yeah I bought the hatchback cluster but the guy sent me a sedan one and then just blew me off when I asked for an exchange for the correct one ... It's still sitting in my dash I haven't had time to correctly secure it in place ...
