Old 01-10-2005, 12:16 PM
bravesfan bravesfan is offline
Question Blower motor won't stop
I found my blower running at high speed this weekend without the car running or the keys in the ignition, they were in my hand as I approached the car. The car had not been running for 24 hours and I know the blower hadn't been running a couple hours earlier as I had walked by the car.
What could cause this and how do I fix it?
Help!!!
Old 01-15-2005, 11:14 AM
automan25 automan25 is offline
Re: Blower motor won't stop
according to a sticker on my blower it says that the fan may run continously if the metal housing is grounded in any way. I'd check for that first.
Automan25
1999 Intrigue GL
3.8 litre engine
Old 02-03-2005, 07:45 PM
prsoto21 prsoto21 is offline
I have had the same problem as you. It has happened 3 times in the past year and a half. I thought it was related to my remote starter; however, after reading your post I am not the only one having the trouble. Randomly my car's high blower will be on and drain my battery. I think once, all the dash intruments were on too, like the key was in the on position. A few days ago my resistor blew and had to replace that, hopefully that will clear up the problem. In the meantime I just bought a Priotity Start battery drain protector as my only savior; I'll put it in in a few days. Any help on this subject is greatly appreciated, I hate going to my car and hearing the blower running and not being able to start my car.
PRS
Old 05-30-2005, 08:13 PM
kept1979 kept1979 is offline
Help!!!
I just started having the same problem with my 1999 Intrigue. Did you find a fix to your problem? If so, what was it?
Thank you
Old 06-03-2005, 11:14 AM
It stopped
So, the motor was just running non-stop and I was pulling a fuse, i forget the exact one, every time I would shut the car off. The more I read about it I learned that if any piece of metal touches it, it will cause a short and the motor will run. So I was going to go out with my voltmeter and check, I put the fuse in, it sparked more than ususal and the motor stopped. It has been running fine ever since. Don't know what I did.
Good luck!!
