Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 01-10-2005, 01:14 PM
cmc444 cmc444 is offline
Dakota Overheating V6
94 V6 dakota engine gets hot. The gauge goes all the way to the H after driving for 10-15 minutes. Never completly overheats but when I stop the overflow tank is bubbling. Also, the heater doesn't work. The heater hose going into the waterpump stays cold the other is hot. I replaced the waterpump, radiator, themostat, all hoses, fan clutch, and have plenty of antifreeze. Any other suggestions. This all started after I had a worn out water pump replaced.
Old 01-10-2005, 01:56 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: Dakota Overheating V6
The heater core must be plugged.
My Mopars
Old 01-18-2005, 12:30 AM
i8uiky i8uiky is offline
have the block flushed and replace the heater core
Old 02-02-2005, 01:24 AM
potapizzle potapizzle is offline
Send a message via MSN to potapizzle
When mine was doing that it was the bypass hose down under the radiator and water pump, if its not the heater core, that could have been installed wrong.
Old 02-04-2005, 09:49 AM
cousincletus cousincletus is offline
Have seen older cars with coolant passages in the head blocked off with scaly rust deposits from neglected maintenance. If you're sure there is no air in the system that is what I would suspect.
Old 02-13-2005, 08:25 AM
who fan who fan is offline
Check the thermostat maybe installed backwards. remove thermostat start engine with radiator cap off look into radiator to see if water pump is pumping. Could be faulty thermostat,(stuck shut) or faulty water pump.
