Old 01-10-2005, 11:16 AM
kzmedic871 kzmedic871 is offline
Angry 4x4 problems w/ 96 s-10 blazer
Hello all,
I am pulling my hair out with this one. My wifes 1996 4.3L S-10 blazer kicks out of 4x4 hi when you accellerate hard or reach about 45-50 mph. I don't mean stomping on it either, for example, driveing down road at 40 mph in 4 hi, accelerate to go around someone and 4x4 disengages. This problem started after the 4wd vaccume switch on transfer case was replaced.
Blazer has manual 4wd shifter on floor. I have re-replaced vac switch on transfer case, I have vac at diaphragm under battery and it engages front axle fine, the diaphragm is new also. I have looked at vac lines from what I can see and they appear to be intact. I have had it back to dealership 3 times for same problem, they always say it is fixed and here I am again.
Any ideas? I could use the help!
Be Safe! Have Fun!
kzmedic871
Old 01-10-2005, 11:19 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 4x4 problems w/ 96 s-10 blazer
Check and replace all vacuum lines if they are at all defective or cracked.
This sounds like a vacuum bleed off.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-10-2005, 11:25 AM
Thumbs up Thanks for the input!!!
thanks for the input Blazer!!! I appreciate you help. I was thinking that should be the next step. I know that I have one vac line supplying the transfer case and then two running up the fire wall. One goes to vent and the other to the diaphragm. Unless I am missing something else, I will check those let every one know.
thanks again...
Be Safe! Have Fun!
kzmedic871
Old 01-10-2005, 11:27 AM
BlazerLT's Avatar
AF -Advisor
Check the connection going to the vacuum ball.
I know my hose there is in bad shape and once I had some idling problems and low and behold, the hose was almost off the ball connection nipple.
Hehe, hey beavis, I said nipple...
Hehe..... YA! ....YA!
Old 01-10-2005, 11:37 AM
Thumbs up thanks again
Thanks again blazer! I will let you know how it turns out. Once again I appreciate your help.
Be Safe! Have Fun!
kzmedic871
Old 01-10-2005, 11:40 AM
BlazerLT's Avatar
AF -Advisor
No prob.
