Strange problem... help please.
I have a strange issue with my 92RS. I mostly just drive my car to work and it pretty much sits in my drive-way over the weekend. My drive to work is about 15 minutes. When I get about half-way to work on Monday morning the car starts acting funny. In first and second gear the car will start cutting out if I don't keep my RPM's up. If I come off the clutch like normal the car will start to cut and I have to throw the clutch back in and rev it up good. It will do this the rest of the way to work. When I leave that evening the car will drive good and it drives great the rest of the week. If I let the car run for about 20 minutes on Sunday evening I don't have this problem. The fuel pump and filter have been replaced recently so I know that those aren't the cause. If anyone could give me some idea as to what might be causing this problem I would appreciate it.
92 RS Heritage Edition 305 (as far as I know) Flow Master Exhaust That's about it |
Re: Strange problem... help please.
are your injectors working properly, and when u had the filter changed did it have some sort of sock type thing on it
i had a 91 that done that same thing, it was a v6, it was my vats shutting it down. (vehical anti theft system)
sounds like an IAC valve or Ignition Control Module.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
get a paper clip under dash driver side close to hood release there a black plugin the top two right holes take paper clip shape in a U plug in to those two holes .After this is done turn key to on not starting service engine will blink 1 blink 2 blinks it will do this three times then it will blink out your code. For example 3 blinks then 6 blinks this is a code 36. After your code is given call autozone tell them your code they will have answer. For anyone else this works upto a 94 gm they changed it too many people not going to them.
flashing should only work on F-bodies up to 92, 93 was an OBDI/II system, and 94 and up is OBDII which requires a TECH2 scanner.
I have an 86 fiero an 88 iroc an 89 gta trans am a 94 gmc jimmy the flashing service light works in all of them
Re: Re: Strange problem... help please.
![]() 1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
I know how to check my codes which I have done quite a few times to get to the bottom of this problem. No codes are being set.
