Old 01-10-2005, 09:49 AM
metallica21156's Avatar
metallica21156 metallica21156 is offline
lowered 95
i have a 95 jiimmy with 4X4. i want to drop it 3". can this be done or what is the max and will the tires on it rub. they are BFgoodrich 205/75 R15 thay are on the stock rims. i know most peple don't lower 4X4's but i'm not off roading and i'd like to have better handleing.can it be done? i was told once that the max i could drop it is 3.5" safely but anything lower is pushing it and if i took out the front drive shaft i could drop it lower.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 01-10-2005, 11:31 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: lowered 95
It can be done for 3 inches maximum.
Remove the torsion bar key bolts for the front drop and use 3 inch drop blocks in the back and you will be huggin the ground.
Be ready to do an alignment after 300 miles after the suspension has adjusted and settled.
Here is what mine would look with a 3 inch drop:
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-10-2005, 04:05 PM
Re: lowered 95
how hard is it to remove the keys? step by step? or should i just use the clamps to lower it. how much faster will the front end wear out?
Old 01-10-2005, 04:16 PM
BlazerLT's Avatar
AF -Advisor
Re: lowered 95
If you look bar along the torsion bars attached to the front suspension, follow them back till you get to a crossmember.
In that cross member will be two bolts sticking down, one for each side.
Backing those bolts all the way out will drop your front end 2-3 inches.
If you want more of a drop, you will have to purchase some some belltech drop keys that allow for even more dropping.
Just be mindful that it is not just a drop and everything is cool.
You will have to get an alignment done after the front settles a bit and this process may accelerate the front ball joint wear.
Don't you currently have other problems with your truck?
I would fix them before you move on to anything else.
Old 01-13-2005, 10:27 AM
Re: lowered 95
if i pull the bolts out and it lowers it can i put them back in to raise it back up? have you ever heard of using speacal clamps to clamp the spring to lower it? my shocks are also starting to get soft. if i replaced them would the handling be better or just the ride? other then that the truck is fine. would the tires rub or should they be fine?
Old 01-14-2005, 01:20 AM
BlazerLT's Avatar
AF -Advisor
Re: lowered 95
We don't have front springs, we have torsion bar front suspension.
Yes, you can raise it back up if you want by reinserting the bolts and tightening them up to where they were before.
You will have to lift the front tires off of the ground to do it though.
Old 01-14-2005, 08:48 AM
Re: lowered 95
will getting new shocks affect the handleing or just the ride?
Old 01-14-2005, 11:08 AM
BlazerLT's Avatar
AF -Advisor
Re: lowered 95
Both, they are directly related.
Old 01-14-2005, 01:22 PM
Re: lowered 95
so by replacing the schicks i'd be able to take corners faster or would it be about the same?
Old 01-14-2005, 01:43 PM
BlazerLT's Avatar
AF -Advisor
Re: lowered 95
Wake up, you are driving a heavy SUV.
Not meant to be taking ANY corner fast.
Old 01-14-2005, 01:46 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Re: lowered 95
Why? Is your beard getting in the way?
Old 01-14-2005, 02:17 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
Re: lowered 95
how much of a lift would you get for turning the torsion bars the other way around to lift it?
Old 01-14-2005, 02:26 PM
BlazerLT's Avatar
AF -Advisor
Re: lowered 95
Not much, plus you don't really want to do that seeing it will really put a lot of stress on the balljoints.
Old 01-14-2005, 02:28 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: lowered 95
Hehe, nice one.
Old 01-15-2005, 10:01 AM
Re: lowered 95
it was just a mis type. i want to know that if you pull the bolts out some will it lower it a little or are they in or out?
