I have to much play in the steeering wheel
I have a 96 GC that the steering is lose I have replaced tie rod ends steering gear. have had two front end alignment one at BJs were I bought new tires and one at the dealer. At the dealer they ajusted the steering gear and I still have the same problem.Could it be lose ball joint ??????
Re: I have to much play in the steeering wheel
Just see if I can respond
An alignment done properly should recognize any problems with the front end, ball joints included. THe tie rods would have adjusted the toe-in, toe-out, the ball joints affect the caster/camber. You could have a worn steering gear in the steering box, also check all te linkage for loose connections. To test your ball joints, jack up that tire just enough to place a jack handle unsr the tire and lift up on the tire, there should not be any play. It helps to have another person looking at the joints while your lifting the tire.
thanks, I checked the ball joint, and they feel tight and the gear box is new and the dealer said he adjusted it but I don,t know if they did it correctly.
also check your wheel hub assemblies and all grease points. if you have a front slip yoke, it will vibrate and sound loose if it's not greased properly.
current rides: 1990 Turbo Miata lifted and locked 96 Grand Cherokee with other toys under the hood retired rides: 1996 Eclipse GSX 1991 Stealth 1991 Porsche 993 C2 1988 BMW 520i Your SUV isn't a Jeep, and my Jeep isn't an SUV.... SCCA, where you actually learn to drive |
