Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 01-10-2005, 06:53 AM
Gcain Gcain is offline
Hard to Start
My 94 Dokato acts like the timing is retarded during cranking. The battery is good and I went through the starter and everything looks fine. It cranks after the engine turns over a few times and runs great, just slow starting at times. Can the electronic ignition cause retarded timing during starting?
Old 01-10-2005, 11:55 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: Hard to Start
"It cranks after the engine turns over a few times"? How does that work?
My Mopars
Old 01-10-2005, 01:19 PM
Re: Re: Hard to Start
Not sure what you are asking--are you serious?
Old 01-10-2005, 02:35 PM
BleedDodge's Avatar
Re: Hard to Start
If it only cranks after the engine turns over a few times, then what's making it turn over to begin with?
Do you mean it clicks a few times and then starts to turn over slowly or what?
My Mopars
Old 01-10-2005, 02:51 PM
No, it doesn't click at all. The starter engages the engine and it starts trying to crank but instead of the starter turning real fast, it acts like the engine trying to "kick back" on the starter. It acts like the timing is "retarded" and gets worse when hot. In older cars I've had experience with, if the distributor was set when the system was firing early, the engine would kick back on the starter which would turn real slow--sometimes even putting such a load on the starter that it wouldn't turn over at all.
Old 01-10-2005, 02:58 PM
BleedDodge's Avatar
Re: Hard to Start
Maybe that's what's happening. If the timing is off even a little bit it won't run right, if at all. Does it sound like it runs on all cylinders when it does start?
What engine is that anyway?
My Mopars
Old 01-11-2005, 05:16 AM
It's the V-6 and it runs great once it starts, plenty of power and idles smooth. Guess my next step is to try to check the timing, can I do that with a regular timing light or do I need to go to someplace where an electronic alalysis can be done? Appreciate some suggestions on this. Thanks
Old 01-17-2005, 11:25 PM
i8uiky i8uiky is offline
Re: Hard to Start
it sounds like a bad starter try a starter load test
