Old 01-10-2005, 04:11 AM
brad2886 brad2886 is offline
Oil cooler lines
Appearantly my oil cooler lines are leaking, but not at an alarming rate thankfully. I was wondering if anybody has change them before on their own and if they have any pointers or tips they can give me.
Thanks.
Old 01-10-2005, 05:19 AM
ricksza's Avatar
ricksza ricksza is offline
Re: Oil cooler lines
Common problem.
Disconnect at oil filter adaptor first and reconnect last.
Use a long (24 inches or longer) extension and 13mm flex socket (or at least an universal joint) to disconnect lower lines off block adaptor. You'll need to go in between the lines.
Slightly jack up driver's side of engine to remove and reinstall lower lines. No need to unbolt mount.
Old 01-10-2005, 07:08 AM
cool thanks for the help...
Old 01-10-2005, 11:42 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Mine have been sweating since new and never leak barely anything.
Most people even have them leak with the new replacements.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-10-2005, 06:12 PM
tom3 tom3 is offline
Mine have seeped for 50K miles now. I wipe them off every now and then. I figure to cut off the old rubber hose part, cut the metal swage fittings with a Dremel, and replace only the hoses with double clamps. Only looking at 60 lbs pressure but would need oil hose that's used for this. Save some real money as those hose assemblies are somewhat expensive. My Blazer is ten years old with 185K miles, if yours is fairly new you might want to go ahead and buy them though.
Old 01-10-2005, 07:02 PM
BlazerLT's Avatar
AF -Advisor
Yea, light seeping is nothing to be worried about.
Old 05-10-2005, 08:32 PM
Sunliner Sunliner is offline
I'm searching the forum for an answer & decided to jump on this thread...
Last week, I noticed a single drop of oil on the bottom of my oil filter. Couldn't see anything dripping from above-couldn't even tell what side of the filter the oil was running down from.
Oil level is fine, survived a 900 mile highway trip with no appreciable loss (going by what the dipstick shows), but every day I check & there's that one drop of oil on the filter; wipe it off, & it's back the next day.
For what it's worth, I last changed my oil & filter in March; the oil on the dipstick is still nice & "honey" colored, though the stuff I see on the bottom of the filter is black (I'm guessing/hoping that it's just picking up grime from under the truck)
Never gets enough built up to hit the garage floor, so it's a slow leak whatever it is.
With 114,000+ miles, do ya think maybe this is the "sweating" from the cooler lines you guys are talking about?
I know that's one of those "needle in a haystack" type questions, but any ideas are appreciated!
As always, thanks!
-Mike
For reference:
2006 TrailBlazer LS
I6 2wd
Automatic trans
~72 k miles
I miss my '97 Blazer...
Old 05-11-2005, 04:57 AM
ricksza's Avatar
The "weeping" usually comes out where the metal line is crimped onto the rubber hose. A drip of oil at the oil filter could be coming from the filter itself, or the seals on the end of the oil cooler lines where it fastens to the filter adaptor. Just check the filter, make sure it's tight. If the filter is okay, I wouldn't worry too much about it.
Old 05-11-2005, 06:10 AM
Thanks Rick;
The filter is good & tight. I'll check the lines at the filter adapter next; is there a seal or gasket at that end, or should I just make sure it's tight?
Thanks again!
-Mike
For reference:
2006 TrailBlazer LS
I6 2wd
Automatic trans
~72 k miles
Old 05-11-2005, 07:39 AM
ricksza's Avatar
The original design has one seal on each tube where it connects with the filter adaptor. The newest design has twin seals. There is also a possibilty that there may be a slight flaw in the mating surface of the adaptor.
Old 05-12-2005, 12:49 AM
BlazerLT's Avatar
AF -Advisor
if the leak is on the bottom of the filter, chances are your oil filter could be over tightened and is squashing the gasket on it.
Remember, only 1 turn MAX after the filter gasket starts to seat.
You don't need to crank them on.
Old 05-13-2005, 01:47 PM
redwheeler's Avatar
redwheeler redwheeler is offline
the oil lones from gm a junk bad crimps
Old 05-13-2005, 04:27 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Oil cooler lines
It isn't leaking from the oil cooler lines, it is leaking from the oil filter assembly.
Old 05-13-2005, 04:37 PM
blazer94's Avatar
blazer94 blazer94 is offline
I had leaking lines; replaced with gm replacement lines (from the dealer) that have a double seal on the end. no leaks. I was warned not to overtighten them on replacement. cost for a full set of hoses was around 72.00.
Trailblazer 2005.
2WD LS
Brand new, No Mods Yet!
Old 09-29-2005, 06:40 PM
rasmith527 rasmith527 is offline
Question Re: Re: Oil cooler lines
Originally Posted by ricksza
Common problem.
How long did it take you to do the oil line change over?
