Old 01-10-2005, 03:58 AM
SsHaDyGt SsHaDyGt is offline
rear speakers crossovers factory amp?
i searched on this and coulnd find anything on it but i replaced my rear 6x9s with a pair of 3 ways now i know that the wires that went to the old 6x9s dont put out all the frequencies* where is the crossover is it an inline or is there a factory amp? ac delco system is what was in it b4
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 01-10-2005, 07:58 AM
WRBsGTP WRBsGTP is offline
Re: rear speakers crossovers factory amp?
there's no amp in the non-bose systems.
Old 01-10-2005, 12:55 PM
ok theres no amp but i still have 2 speakers in the back the 6x9 and the 4 inch tweeter where is the crossover for the rear speakers
Old 01-10-2005, 01:05 PM
Chazman Chazman is offline
There may not be a "crossover", is there a small black round thing attatched to the terminals on the four inch? If so this is a inline filter - only allows certain frequencies to pass.
Old 01-11-2005, 08:10 AM
DL1030 DL1030 is offline
the 6x9's only play low freqs, if you want to add a x-over and 3 ways use the wire from the 4" speaker instead. the 4"s get full range(minus the attn from the HU itself). Which HU do you have? 7band or BOSE(2 band slider)
Old 01-11-2005, 08:27 AM
while we're on the subject of speakers, i've been thinking about replacing mine, but keeping the factory HU. It's non-bose. What's the max wattage I should get if I want the best sound from front and rear component speakers?
Old 01-11-2005, 09:45 AM
for the aftermarket speakers you want a low RMS and a high sensitivity. the stock HU pumps out ~12WRMS.
Old 01-13-2005, 08:46 AM
how low should the rms be? is 86-90 db a good sensitivity?
Old 02-23-2005, 02:49 AM
i have replaced my headunit with a pioneer and i noticed that the wires in the back dont put out the same frequencies where do they split up? i dont have the bose unit but i have seen the "non bose factory amp" for my car for sale on ebay?????
Old 02-25-2005, 12:31 AM
deb0704us deb0704us is offline
Send a message via AIM to deb0704us Send a message via Yahoo to deb0704us
I replaced my rear speakers with 3-ways. No one told me I needed an amp when they were purchased and installed. But obviously i do. Is there some rewiring that could help this problem rather than paying for an amp?
Old 02-25-2005, 02:50 PM
does anyone have the wiring diagram? you wouldnt need an amp if you could eliminate the iinline crossovers
