Old 01-10-2005, 01:47 AM
texwill texwill is offline
largest tires for stock 94?
I want to stick some larger tires on my 94 s-10 4 door. I am going to lift it about 2 inches, and add a rear add a leaf in the back, but that will be later on down the road, but does anyone know how large of a tire you can stick under the truck without lifting it?
Old 01-10-2005, 01:55 AM
jakes900 jakes900 is offline
Re: largest tires for stock 94?
44 super swamper as long as your not to attached to your fenders. You might have to trim a tiny bit.
Old 01-10-2005, 02:05 AM
No, not that big, I do not want to trim the fenders or anything, I have about 31" right now and they work fine, but I would like something a little larger with slightly more aggressive tread. Like maybe the Wrangler MTR.
Old 01-10-2005, 02:58 AM
I was just joking stay with you 31's you start going any bigger your going to have to change your gearing in order to use it for offroading. Then you have to start upgarding powertrain to handle added weight along with upgrading your brakes. By the time your start adding everything up you would be better of swapping out the entire front and rear if you want to go big.
Old 01-11-2005, 04:33 AM
slreno1217 slreno1217 is offline
i have a 96 and i got the 30x9.50x15 bf goodrich all terain TA KO.. these tires are AWESOME they even gaurentee them for 2 years not to get stuck period.. if it does they come and tow for free. also give you a special card with number to call for towing asist.
same tires on the hummer.
Old 01-11-2005, 05:24 AM
Thanks for the info!
