Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-09-2005, 11:35 PM
dbmcnair dbmcnair is offline
Question turn signal bulbs
How do you change a turn signal bulb in a 1996 crown vic?
Old 01-18-2005, 01:28 PM
landyacht's Avatar
landyacht landyacht is offline
You can un-screw the cover for the light just under where the hood closes. Then when it's loose, you pull the wire out, change the bulb, put the wire back in, and bolt the cover back up.
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
