Go Back   Automotive Forums Car Chat > Honda > Classifieds
Classifieds This is the place to buy and sell your Honda parts.
Old 01-09-2005, 10:14 PM
NA97GSR NA97GSR is offline
Built Engines Gsr B18 Sleeved Turbo B16 Pics
SELLING MOTORS LEFT AT MACHINE SHOP THAT COULDNT BE PAID FOR. PICK-UP IN NY/NY/PA/CT/DL AREA. WILL SHIP AT BUYER'S EXPENSE. PAYPAL! PM, EMAIL [email protected] OR CALL ME AT 609-954-8466. PLEASE READ ENTIRE DESCRIPTION. ALL 100% LEGIT, INCLUDES RECEIPTS, VEHICLE HISTORY REPORT AND VIN PLATES ATTACHED. MORE PICS AVAILABLE UPON REQUEST. SEND YOUR EMAIL ADRESS.
CLICK HERE FOR PICS: http://pictures.sprintpcs.com/share...Z2y5kUK3h1kzU3U
SLEEVED AND PINNED B18A LS BLOCK, 84.5mm BORE. NO CRANK RIODS PISTONS $1000
COMPLETE 96 GSR SHORTBLOCK W/ OBD2 CRANK ANGLE SENSOR, 0 (ZERO)MILES, NEW BEARINGS, SEALS, GASKETS, RINGS, VTEC OIL PUMP, VTEC WATER PUMP, STOCK RODS, JDM TYPE R PISTONS 11.1:1 TO 11.3:1 COMPRESSION, THERMOSTAT HOUSING, COOLANT PASSAGE, OIL PRESSURE SENSOR. GSR TIMING BELT, FLYWHEEL, TB COVER, CRANK PULLEY, ETC.. $1300 OBO
COMPLETE B18B LS BLOCK, FOR LS/VTEC , NEW RACE BEARINGS , SEALS, GASKETS, VTEC OIL PUMP WATER PUMP, JDM TYPE R PISTONS. 11.5:1+ COMPRESSION. ARP RODS BOLTS, ARP MAIN BOLTS, RECONDITIONED RODS, FLYWHEEL, CRANK PULLEY. $1300 OBO
COMPLETE LS/VTEC MOTOR WITH GSR HEAD, W/ OBD2 CRANK ANGLE SENSOR, 0 (ZERO)MILES, BORED .20 OVER, NEW BEARINGS, SEALS, GASKETS, RINGS, VTEC OIL PUMP, VTEC WATER PUMP
B18A1 BLOCK, MICROPOLISHED CRANK, STOCK RODS, JDM ITR PISTONS, THERMOSTAT HOUSING, COOLANT PASSAGE, OIL PRESSURE SENSOR, NEW GSR TIMING BELT, FLYWHEEL,
REBUILT GSR HEAD, NEW VALVE SEALS, 3-ANGLE VALVE JOB, STOCK CAMS, VALVES, SPRIGNS RETAINERS, INTAKE MANIFOLD, AEM FUEL RAIL, VTEC OBD1 INJECTORS, VALVE COVER, TIMED AND READY TO GO!! 11.7->8 :1 COMPRESSION W/ GSR HEAD $2000 FIRM
2003 S2000 COMPLETE MOTOR (HEAD AND BLOCK), NO TRANS, ONLY 20 (TWENTY) MILES, NEEDS TO BE BORED OVER OR SLEEVED, DUE TO SCRATCH ON WALL OF ONE CYL. CRANK RODS AND PISTONS 100%, CYL HEAD ALSO 100% INCLUDES ALL INTERNALS AND CAMSHAFTS. ASKING $$2800 OBO CONTACT ME FOR MORE INFO.
LEGIT 94 ACURA INTEGRA LS SWAP, 5-SPEED TRANS, ECU, HARNESS, AXLES, NO LINKAGE OR HALF SHAFT, LOW MILES, SUPER CLEAN $1400
2000 SI B16 BARE BLOCK W/ MAINS AND WITH CRANK $200
2000 SI B16 BARE BLOCK W/ MAINS, NO CRANK $100
B18B LS BARE BLOCK $200 NO CRANK
SKUNK2 REAR UPPER STRUT BAR LIKE NEW FOR 94-01 INTEGRA AND 92+ CIVICS $150
5. JDM B16 HEAD, PORT AND POLISH ON INTAKE AND EXHAUST, NEW REV STAINLESS RACING VALVES, NEW TITANIUM RETAINERS, NEW TYPE R VALVE SPRINGS, NEW VALVE SEALS. VTEC SELENOID, POLISHED VALVE COVER, GSR CAMS AND GEARS. COOLANT PASSAGE, INTAKE MANIFOLD, $800
B-SERIES VTEC SKUNK2 STAGE2 CAMS WITH SILVER AEM GEARS $500
6. 2000 S2000 F20C1 LONG BLOCK. NEEDS MACHINING AND NEW OVERSIZE PISTONS, 15K MILES, INCLUDES HEAD AND CAMS, BLOCK CRANK AND RODS ALL 100%, TIMING CHAIN, OIL COOLER, OIL PUMP, WATER PUMP, ALUMINUM PAN. NO VALVE COVER, OR TRANS. CONTACT ME FOR MORE INFO. $3000obo
2000 CIVIC SI B16 BLOCK, RUNNING CONDITION $500
2 2000 CIVIC SI BARE BLOCKS, BOTH WITH CRANKS $200 EACH
ALL PRICES ARE PICK UP IN NJ/NY/PA/DL/CT AREA. CALL ME AT 609-954-8466
THANK YOU
DV
