Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 01-09-2005, 10:16 PM
r8rcj7 r8rcj7 is offline
ignition issue with my 85 cj7 with inline 6
One day I was driving and it cut out. The vehicle has not started since. So far, I've replaced the ignition module, the coil, and have improved the positive terminal voltage at the coil from 7.3 to 11.5v by doing some wire replacements. When I pull the coil spark wire from the center of the distributor and place it 13mm from a good ground, I get a spark intermittently but obviously not enough to start it. I'm at my wits end and I'm ready to roll it off of a cliff. Anyone out there have any suggestions of what I should do next?
Old 01-14-2005, 03:42 PM
dreymeek dreymeek is offline
What kind of ignition system, Autolite or Prestolite? You could have distributor problems, bad pickup module, rotor air gap off, etc. How about timing? Did it move? Is the cap cracked? Crank it in a totally dark garage and see if you see sparks shooting out of the wires, cap, coil, or anywhere else. Good luck!
Old 01-14-2005, 05:57 PM
Re: ignition issue with my 85 cj7 with inline 6
Thanks alot for your reply. I just picked up a new pickup coil today. I'm going to install and pray. Thanks again
