Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-09-2005, 08:13 PM
musick musick is offline
Post T. control, and abs light
I'm an owner of a lovely 1997 aurora. Only it has a problem with with the traction control and ABS lights remaining on. The lady I bought the car from said she replaced the speed sensor but it didn't work. The lights still remained on. Thats it? Thanks for any help!
Old 01-09-2005, 09:35 PM
indyboom's Avatar
indyboom indyboom is offline
Re: T. control, and abs light
You may have a bad .. Well I thinkd its called a power control valve. It is in your abs system. I have te same problem, only myabs is good
INDYBOOM
Old 01-09-2005, 11:04 PM
ghutchin ghutchin is offline
I would suggest getting the codes scanned. If the code is for the speed sensor that was replaced there may be an issue in the cable harness. My right rear harness actually turned to dust in certain parts when I started messing with it due to heavy corrosion.
Old 01-10-2005, 11:14 AM
GuMan GuMan is offline
My valve body had to be replaced because one of
the solenoids went bad in it. I was able to pull
the connector of the ABS computer, near the
master cyllinder, and measure the appropriate pins
on the harness to see if each solenoid was still
intact. The shop manual walks you through this.
However, the codes will be set, so if you are not
electrically inclined, and don't want to get way
down into the engine compartment to change the
abs valve body, go to the dealer.
Old 01-10-2005, 03:10 PM
RoraStar96's Avatar
RoraStar96 RoraStar96 is offline
Send a message via AIM to RoraStar96 Send a message via MSN to RoraStar96 Send a message via Yahoo to RoraStar96
1. Scan for codes.
2. Ensure sensor connection from WSS on the wheels are connected.
3. You may have a bad ETCBM (electronic traction control brake module...ie the brake computer)
If the WSS/hub has been changed then I recon its the ETCBM
I've had this happen, replaced the computer for $125 CDN at a wrecker yard. OE price $1100 CDN
Good luck.
1997 Aurora
"Aurora Snow"
250++HP 4.0L Modified Aurora V8 w/Autobahn Performance
On Deck: RSM intake, RSM 80mm TB
Administrator, www.oldsmobileforums.com
Administrator,Aurora Club of North America
Administrator, www.bonnevilleclub.com
Adminstrator, www.ontariobonnevilleclub.com Coming Soon
Old 01-13-2005, 10:17 PM
thanks for the help everyone
