97 ram 4x4 won't run
have 318 engine. Will crank over but not run. Checked computer codes and tells me Camshaft position sensor A Bank 1 circuit malfunction.
I have changed the wires, cap, rotor and crankshaft position sensor. So far still no spark, got fuel. I have 108,000 mls. Called dealer and told me I don't have a camshaft position sensor, change the crank sensor. Anybody have any ideas? |
Re: 97 ram 4x4 won't run
your scanner is not confused but your dealer should know this what your scanner calls the cam sens is actually your pickup coil in your distributor dont try to repace it just buy a dist
Re: Re: 97 ram 4x4 won't run
Why replace the whole distributor, vs. just the pick up coil |
Re: Re: Re: 97 ram 4x4 won't run
Just wanted to thanx vrooks for the info. It turned out to be the pick up coil in the distributor and she is purring fine again. Turned out somehow two of the 3 wires were broke.
