Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-09-2005, 04:31 PM
kakjinx kakjinx is offline
Send a message via AIM to kakjinx Send a message via Yahoo to kakjinx
Idle Problem
When i let the engine idle, it seems like it has a miss to it, but when i get it up to higher RPM's it runs great. i have tried many different things and still no luck. The timing is set right, and there are no vacuum leaks that i am aware of.. also replace the 2 coolant sensors. the one that goes to the computer as well as the one to the dash.. if anyone has any ideas out there please help me... you can leave me a msg on here, or on my yahoo msgr.. S/N reaper__69 or e-mail me. [email protected]
Old 01-09-2005, 04:57 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Idle Problem
Check and clean the idle air control motor. The valve on the end is probably dirty and causing it to idle rough. Not sure what year car you have but on most of the newer cars this will solve the probelm very easily at little or no cost. To clean it simply remove it, spray with carb. cleaner, allow to dry and replace on the car. Takes just a few minutes to do and will probably solve your idle problem.
Old 01-12-2005, 09:10 AM
jrgong jrgong is offline
Send a message via AIM to jrgong
I had the same problem with my 1999 Olds Alero a couple days ago....
The mechanic replaced a split line leading into my intake, and now its all good... the diagnostic was $50, plus $30 for parts and labor
Old 01-12-2005, 09:44 PM
april15_ april15_ is offline
Does it also hesitate when you step on the gas from a stop? It may be the ignition coil housing.
Old 01-16-2005, 07:00 PM
njdjh2o njdjh2o is offline
Re: Re: Idle Problem
Where is the idle air control motor, is it on the intake, because I'm having the same problem.
Thanks
Old 01-17-2005, 06:00 AM
Pontiac Guy
Re: Idle Problem
It depends on the engine but the IAC motor is usually located on the throttle body. If you let me know what size engine you have I will get back to you with the location.
Old 12-02-2005, 06:09 AM
tr 1860 tr 1860 is offline
Re: Idle Problem
where is iac located on 1990 3.1? thanks for anyhelp.
Old 12-02-2005, 07:05 AM
Pontiac Guy
Re: Idle Problem
It should be located on the side of the throttle body. Clean it with throttle body cleaner and do not move the pintle when you are cleaning it.
Closed Thread
