Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-09-2005, 03:40 PM
Green Machine 95 Green Machine 95 is offline
Send a message via AIM to Green Machine 95
powering steering gone (reads CHECK SYSTEM CHARGE)
I was driving my car and all of a sudden the power steering went out, the battery volt light came on, and 'check system charge' came on. I checked the fluid, it was running low, filled it up, and it hasnt fixed it.
Anyone know what the problem could be?
95' Aurora: Luxury at its best, with a little speed on the side
www.smorgas.com/awnawhellnaw
Old 01-09-2005, 04:21 PM
Retro-D Retro-D is offline
Re: powering steering gone (reads CHECK SYSTEM CHARGE)
Check the serpentine belt, maybe it broke or seized on an accessory.
RD
Old 01-09-2005, 04:57 PM
chris_fit chris_fit is offline
Send a message via AIM to chris_fit
Also check the alternator.
Old 01-09-2005, 08:10 PM
The Rebel The Rebel is offline
Re: Re: powering steering gone (reads CHECK SYSTEM CHARGE)
Your joking right? I think you would notice the belt off the pulley?
If the serpentine belt (Gates) is still on check the drive way & engine area to see if there is fluid. You may need a hose (upper or lower) or even the pump itself. Hows the steering?
Old 01-09-2005, 09:28 PM
its hard as shit to make any turn, the battery voltage runs at about 12.3...12.4
Old 01-09-2005, 11:06 PM
ghutchin ghutchin is offline
If you lost both powersteering and the alternator is out its a pretty safe bet that something is wrong with the belt.
Old 01-09-2005, 11:13 PM
i drove the car still, the car still ran and seemed fine...
Old 01-09-2005, 11:16 PM
Yeah it will run fine until the battery dies. This should be an easy inspection. Also with this car since the water pump is drivern off of a separate belt you wouldn't have the overheating issues associated with other cars that loose their main drive belt.
Old 01-10-2005, 05:43 PM
oldsdad oldsdad is offline
Send a message via Yahoo to oldsdad
Sounds just like when my belt broke first no power steering then DIC shows battery drain and alt. light comes on drove it home replaced the belt runs great now. Check your belt more than likely thats the problem. Yes you can tell the weight of the car and the width of the tires when you try to steer not fun for sure.
Old 01-10-2005, 07:22 PM
yea, making a left turn with a 2 ton car with no power steering is pretty damn hard heh
Old 01-10-2006, 09:03 AM
LarsBars LarsBars is offline
My wife just called and is stuck at a gas station with these exact problems. Looks like I am going to have have it towed home. I will let you know if the belt is broke.
Old 01-10-2006, 10:03 AM
I hope it's not caused by a seized A/C compressor like what happened to mine.
Good Luck,
RD
Old 01-10-2006, 10:21 AM
Good Luck,
RD
Belt was shredded. I will change and hope it was just an old belt.
Old 01-10-2006, 11:47 AM
Indy8's Avatar
Indy8 Indy8 is offline
Along the topic of belts, may I suggest to everyone to carry both spare belts in the car in a sealed bag heavily coated with silicone spray to stop dry-rot. Both can be changed on the side of the road in ten minutes.
Quality isn't expensive, it's priceless.
