Old 01-09-2005, 02:57 PM
LindaJT LindaJT is offline
Question 02 Cav. making bad noises!
I have a 2002 cavalier, 2.2L standard transmision. I was at a stop light when it suddenly sounded someone was rattling a metal can filled with marbles under the hood. I drove it home (1 hour trip) and the engine ran fine, no warning lights on, same gas mileage, no loss of power, ect., just that loud noise! (the noise is there both when idling and driving). It was originally diagnosed as a bad drivebelt idler pulley, but that was replaced and the noise is still there. Anyone have any idea what might be causing this? I can't afford to pay a garage to take it apart and guess, so any help you can give me would be greatly appreciated!
Old 01-09-2005, 07:37 PM
public's Avatar
public public is offline
Re: 02 Cav. making bad noises!
Check your exhaust system, could be making contact somwhere.
Yes, I am retarded.
Old 01-09-2005, 09:38 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Possible A/C compressor... that makes a tinging noise..
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-10-2005, 12:19 PM
Re: Re: 02 Cav. making bad noises!
I have checked the exhaust and that is tight....
Would the a/c compressor make that noise if the a/c isn't being used?
Thanks for the suggestions....got any more?
Old 01-10-2005, 08:55 PM
Cava_Z Cava_Z is offline
Actually, it's when the A/C is not in use when it's most likely to make that noise and it goes away when you turn on the A/C. Turn on the A/C and see if the noise stops and if it does have your compressor checked.
Old 01-12-2005, 12:03 AM
bigdaveangell bigdaveangell is offline
Re: Re: Re: 02 Cav. making bad noises!
I doubt its the ac compressor unless its just the pulley. There is a clutch that engages the pulley to the compresser when the ac is turned on
Old 01-12-2005, 07:20 PM
public's Avatar
Perhaps you have a metal can filled with marbles under the hood.
Sorry. I am afraid you are going to need to get under the hood while the car is running in the driveway and listen to narrow down where it is. You may find a mechanic's stethoscope very handy. You can get one at any parts store for $10 or so. Good Luck.
Yes, I am retarded.
Old 01-12-2005, 11:16 PM
a screwdriver will also work to pinpoint where a noise is coming from
Old 01-13-2005, 04:03 PM
public's Avatar
Yep, I used one for years. Also had a setion of a broom handle. Both worked fairly well. The just stetho' is nice because you hear in both ears.
Yes, I am retarded.
Old 01-23-2005, 01:37 PM
Well, I have had to break down and take the car to a garage....I will post the diagnosis in case it would be of help to anyone in the future.
Thanks for all the suggestions everyone!
Linda
Old 01-23-2005, 10:27 PM
noshun's Avatar
noshun noshun is offline
Linda
Is you clutch acting the same, ei is it slipping at all? It may be a busted spring on the pressure plate if you exhause every other mentioned possiblity. With the screwdriver they meant rest your ear on it with the meatl end touching parts of the motor. just in case that was unclear!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-24-2005, 06:33 AM
The clutch is fine....no problems there. They seem to think the noise is coming from inside the engine, so my fingers are crossed and I am praying that it is something simple and CHEAP to fix!
Thanks again,
Linda
Old 01-24-2005, 09:37 AM
Lifted GMT-360!
I still say is your A/C compressor... i had that annoying noise from mine and had it replaced..
Old 01-24-2005, 10:22 AM
noshun's Avatar
Thanks again,
Linda
Hope it's not a piston hitting a valve for your sake!! Good Luck
Old 02-02-2005, 09:28 AM
Good news! I just got my car back and it was the idler pulley for the drive chain. The mechanic stopped by my house to listen to the noise, came back and towed it to his garage AND dropped it off at my house after fixing it. He did all of this for only $154! Thanks for all of your suggestions!
Linda
