Old 01-09-2005, 02:47 PM
MJTrippy MJTrippy is offline
Send a message via AIM to MJTrippy
water temp gauge
just today all the sudden the temp gauge doesnt move past 110, and i have been driving it for about a hr now and still doesnt move, normal in this weather it goes to 190 but now it doesnt move, checked fuse, (not blown).... dont know what to do and what can i check to fix it????
Old 01-09-2005, 04:03 PM
ricksza's Avatar
ricksza ricksza is offline
Re: water temp gauge
Check you coolant level. Do you have normal heat out the vents? If you have normal heat, but low temp readings, probably temp sensor. If low heat also, probably bad thermostat.
Old 01-09-2005, 04:08 PM
yea it still has awesome heat i mean it blows like normal hott air but the gauge still reads low, where is the thermostat? and the temp senser? and yes the coolent level is where it is suppa be thanks....
Old 01-09-2005, 04:50 PM
blazee's Avatar
blazee blazee is offline
Problem?
If you heater is working good it's probably your temperature sending unit and not the thermostat.
FYI:
The thermostat is in the housing where the upper radiator hose enters the top of the engine.
And I believe your temperature sending unit should be on your driver side cylinder head right above the number 3 and 5 sparkplugs. It will have a small wire connector going to it.
Old 01-09-2005, 06:56 PM
Re: Re: water temp gauge
FYI:
hello now where is the sending unit like how many wire's are going to it? and whats it look like from the outside
thanks
Old 01-09-2005, 06:59 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Thermostat needs to be changed.
It is stuck open.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-09-2005, 07:08 PM
where is the Thermostat and now the temp droped to 100 wile it was off and wont even move now no mater how long the motor is on
Old 01-09-2005, 07:20 PM
blazee's Avatar
Problem?
It is stuck open.
You didn't read the whole thing it's not the thermostat, it is the sending unit.
Old 01-09-2005, 07:23 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: water temp gauge
I read the friggin post.
Just because there is heat doesn't mean the thermostat is not stuck open.
Old 01-09-2005, 07:26 PM
ok now where is the sending unit, like what does it look like i cant see it? how many wires it got on it..... and how do i test it
Old 01-09-2005, 07:28 PM
blazee's Avatar
Problem?
Re: Re: Re: Re: water temp gauge
did you read the part that says his heater blows hot and the temperature gauge doesn't move? Yes if the thermostat is stuck open it will run cooler, but the temperature gauge will show more than 100.
Old 01-09-2005, 07:32 PM
ok it blows cool air when fist turned on but after about 10 min after driving around like any other day the heat gets hott and temp would read about 190 and blow hott, now still blows hott after driving around 10 min but now the temp gauge dont move now, wont move off of 100
Old 01-09-2005, 07:45 PM
blazee's Avatar
Problem?
"your temperature sending unit should be on your driver side cylinder head right above the number 3 and 5 sparkplugs. It will have a small wire connector going to it." If you take a look it is pretty easy to see, it is a few inches above the back two sparkplugs on the driverside and about half way between them. looking down it will look like a stud (almost like a sparkplug) with a wire harness plugged into it.
Old 01-09-2005, 07:59 PM
Turbocpe Turbocpe is offline
It would be good if you could have someone hook up a scantool to your Blazer so that they can read what temperature the engine is reporting to the computer itself.
Sure would save replacing parts that aren't needed.
Judging by the info here, I would suspect the sending unit or gauge, especially if you have "awesome heat" still.
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: Re: water temp gauge
That in no way takes a stuck openthermostat out of the equation.
I am not saying that it is not the sender, but let's not jump to conclusions and state that the stat is fine.
