Old 01-09-2005, 11:46 AM
recurve's Avatar
recurve recurve is offline
Question Stiff emergency brake
Hello,
Our '97 Blazer is having trouble with its emergency brake. It is slowly becoming stiffer and stiffer to engage. Also, when we release the emergency brake, the pedal comes up from the floor but the warning light on the dashboard says it is still engaged. We have to push the emergency brake pedal firmly all the way down to the floor and then release the brake for the dashboard light to go off.
For the time being, I've stopped engaging the brake. Any ideas about how to correct this is appreciated :-)
Thanks,
-- recurve
Old 01-09-2005, 01:12 PM
Fractured1 Fractured1 is offline
The emergency blake cables can become contaminated with rust and corosion over the years, usually back on the frame rails towards the back drums... you can try some wd/40 on them where the cable enters the sheath, and working the emergency brake a few times...good luck and because of working underneath with rust and spray lube wear eye protection!!!
Old 01-09-2005, 02:36 PM
molehole's Avatar
molehole molehole is offline
Send a message via AIM to molehole
Re: Stiff emergency brake
Also make sure your rear brakes are adjusted properly. Could be they are binding up or something. It probally is the cable though. Try to grease it up and if that doesn't work you can replace for pretty cheap. Good Luck
Old 01-09-2005, 07:02 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
I don't use the emergency brake.
And this is the reason why.
Also, your emergency brake is probably permanently engaged.
Better get it checked fast.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-10-2005, 09:33 PM
recurve's Avatar
Thanks for all the information guys! I'll try to clean up the cable.
