Old 01-09-2005, 11:30 AM
GSR2NR94's Avatar
GSR2NR94 GSR2NR94 is offline
Send a message via AIM to GSR2NR94
Heater Doesn't Work???
Hey guys. My girlfriend has a 98 Grand Prix and the heater just stopped working yesterday. What could cause this?
"Drifting is a passion, make love to a corner."
Old 01-09-2005, 11:48 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Heater Doesn't Work???
Tsat.
Old 01-09-2005, 04:19 PM
GSR2NR94's Avatar
What The Hell Does That Mean?
Old 01-09-2005, 04:20 PM
GTX Playa's Avatar
GTX Playa GTX Playa is offline
Send a message via Yahoo to GTX Playa
I believe he meant t-stat. Your thermostat is probably stuck closed.
Old 01-09-2005, 04:27 PM
GSR2NR94's Avatar
But if my thermostat was stuck closed, then it would still blow out air, just not warm air. Her heater blows out NO air at all. I think most car heater's are wired direct for the heater, so there is no fuse. I could be wrong, but I am leaning towards the blower motor maybe.
Old 01-20-2005, 07:23 AM
zzjktr zzjktr is offline
Re: Re: Heater Doesn't Work???
Have the very same issue - parked car at airport - very cold weather for 3 days and no blower motor. Made it difficult to get home. Next day still no blower motor, then after filling up with gas the blower motor comes on. So far it has been hit and miss.... wondering about the circuit board above the blower motor... anyone else have this issue?
Old 01-20-2005, 10:15 AM
BIG-L's Avatar
BIG-L BIG-L is offline
Since we seem to have problems with water/moister getting into the HVAC box,it could be freezing up the bushing for the motor and causing it not to spin.Might be time to pull the fan motor and clean & lube it up.
~Larry~
ClubGP Member 6530
Since 2001
Old 01-20-2005, 08:14 PM
candywrapper candywrapper is offline
Okey;
first; when your fan motor doesnt work, with the heater on high, go and pop the hood. get a wrench or something to tap on the heater housing ,usually on the firewall of the car on the right side(where the fan motor is located)
a few times. if it kicks on, this is a sign that your fan is wore out. You can get a new one at Advance Auto or Auto Zone for 20 to 30 $$
Old 01-21-2005, 05:49 AM
OK I've been watching mine alot closer. Seems that when I start the car and it's cold 6-10 degrees and wait for it to warm up I mean running temp 180-220 shut the car off and restart it my blower motor will operate normally no missing speeds etc. I have noticed that the light on the display seems to act a little funny. Still seems like it has the potential to be the stupid little circuit board? My other vehicle is down at the moment so as soon as I can I will have my circuit board replaced to see if that does the trick.
