Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 01-09-2005, 10:59 AM
johandk johandk is offline
Low Beam Stays On
Hi,
I hope someone can help me please.
I have a 1988 735i.
Drove the car with headlights on and after I have switched off the car and turned off the headlights both the left and right side low beams does not want to go off.
If I unplug the KLM unit from the fuse box the light goes out but the moment I put it back the low beam is on again.
Thank you very much.
Johan de Klerk
Old 01-10-2005, 06:57 AM
libertylover libertylover is offline
The LKM is notorious for bad solder joints and it makes crazy things happen to the lights. Do a search of the E32 section at www.roadfly.org and you'll see what to look for.
Old 01-15-2005, 12:18 AM
Hi,
Thanks for the advice.
I took the KLM apart and found that it was one of the relays that was stuck.
It is working normal now again.
Johan
