1990 Riviera poor idle
I have a 1990 Buick Riviera with a 3800 v6 that has a slight idle problem. Here is the scenario. At idle in park the car had a rather decent mis to it. I checked the codes and got code 48, which is a misfire symptom. Ok, i already knew that. I check all the wires and plugs and found out that the #4 plug wire was arcing off on the O2 sensor wire. So i changed plugs and wires both. being that i just got the car i thought it to be a good idea to do that anyways. Ok, that cured the misfire that i once had. But, this car has a very poor idle, almost like it is lopping. The idle is about 800 RPM like it should be. But it will not keep a good idle at all. it will fluctuate badly from about 500 RPM's to about 800 RPM's and vice - versa. I have checked the codes again and all is well not a single code at all. I have checked the TPS and it seems to be just fine. I can move the lever and it will stop doing what it does, this is still while in park. I adjusted the TPS to not do this anymore and all seems ok until i put it in reverse or drive or anything other than park or neutral. The problem comes back. Should i replace the TPS with the factory one, even though i am not getting a code. Or could it even possibly be in the coil. I know it is something minor, just thought i would ask some advice of the good people here at this site. Thanks in advance.
Re: 1990 Riviera poor idle
How do you adjust a TPS ??
Re: Re: 1990 Riviera poor idle
I have a 90 buick Riv as well and i have the same exact problem in neutral or park it idles fine but in drive it lopes. Might just be a factory problem.
I would remove, clean and replace the IAC. Reattas have this same problem. Enjoy FlyByNite |
