Old 01-09-2005, 09:55 AM
FinzUp FinzUp is offline
Axle Ratio/Towing Capacity
Greetings,
I have a 03 Trailblazer LT EXT (4.2 I6) and I am thinking about buying an RV. I am confused about my towing capacity because I do not know the Axle Ratio -- which, according the the owners manual, is something I need to determine the towing capacity. Where can I find the axle ratio?
TIA!!!
Old 01-09-2005, 10:10 AM
Thanks for the reply. I do not have the original window sticker -- so I guess I will call the dealer.
Thanks again!!
Old 01-09-2005, 08:33 PM
lkurek lkurek is offline
Re: Axel Ratio/Towing Capacity
Take a look in the glovebox for the RPO codes (three letter/number codes on a sticker). See what the "G" codes are. GU6 is the standard and most common, 3.42 ratio. 3.73 and the 4.10's were optional...which I think were GU7 and something else. Not sure what, but I can look it up if you have something different. FWIW, if you have a G80 code, it means you have a limited slip in the back...
Old 01-10-2005, 07:30 PM
baskerj baskerj is offline
Towing capacity should be located on the doorjam sticker. The same place where tire inflation recommendation is located.
