Old 01-09-2005, 10:39 AM
nomad77 nomad77 is offline
98 won't start after sitting more than a day
I've got a '98 Blazer V6 that doesn't want to start after not being driven for more than a day (actually got to stay home on my day off!). It has done this once before, about 2 months ago, but cleared up by the time the battery (which I replaced afterwards) was charged up. The rotor appears to be fine, but will most likely be the first thing I replace now. The distributor cap is brand new, the plugs/wires only have 35k on them, and I *really* don't want it to be plugs - not fun doing those things . I just tested the coil, which is reading no/low/infinite resistance in all the right places.
Symptoms:
No start condition
Engine cranks fine, but will not run
Cranking for 5 or more seconds and letting off starter makes the engine sputter and partially fire for a few revs
The fuel pump engages attempting to start up, and I can smell gas afterwards, so I don't think it's a fuel starvation problem. Has this thing jumped timing on me or something? I'm running out of ideas.
Oh, and on a side note - how do you air these Vortec's out if they get flooded? Take the plenum off and blow hard? Give me back my carbureted '82 Camaro !
Old 01-09-2005, 11:46 AM
Fractured1 Fractured1 is offline
I think the first thing I would go for is a test on the fuel pressure...you may be able to rent a tester at autozone (not sure)...have you actually tested for spark at the plugs...keep us posted
Old 01-09-2005, 12:22 PM
Re: 98 won't start after sitting more than a day
Actually, I haven't tested the pressure yet, as I replaced the pump/filter/relay last fall - but on advice, I will now. I'm in the process of pulling the plugs now, I'll test for spark on replacing the wires.
Thx for the reply Fractured
Old 01-09-2005, 01:12 PM
slreno1217 slreno1217 is offline
Symptoms:
No start condition
please post fix.. mine is doing exact same thing to the T. on a 96 blazer.
Old 01-09-2005, 02:01 PM
Just a curious thought...did you check the coil after you ran the Blazer for a bit...Don't know if I dreamed it or read it somewhere but your readings could be different once it heats up..maybe someone could clear this up for me...Damn dreams, lol...
Old 01-09-2005, 02:27 PM
Well, I would love to test the coil after it's been run for a bit - unfortunately, that's the entire problem, it won't start . I'm waiting on my ride to Auto Zone to go get a fuel pressure tester (my blazer's my only vehicle atm). I'm highly doubting it's fuel, as I've been getting a strong smell of gas after my attempts to start it. I've pulled the plugs and a couple are in rougher shape than I'd expect, but then again, they're not platinums, just standard AC Delco's. Not watching what I was doing when I bought my replacement set, I gave Pep Boys (10 miles closer than Auto Zone) the wrong part number and got the same ones - have to take them back and get plat's.
As soon as I can figure this @#$% out slreno I'll post it here.
*edit*: Been a while since I've used the technique - is the preferred method of testing spark at the plug still pulling said plug and holding it to a ground and have someone crank the engine?
Old 01-09-2005, 05:56 PM
Bigjohntool Bigjohntool is offline
nomad77 what did you find out about your blazer.i have the same problem.
Old 01-09-2005, 07:52 PM
someone help
Old 01-09-2005, 08:00 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
When is the last time you replaced the cap and rotor?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-09-2005, 08:09 PM
2 days ago
Old 01-09-2005, 08:11 PM
new pump an filter to. i have spark an 60 psi it just wont start
Old 01-09-2005, 08:22 PM
BlazerLT's Avatar
AF -Advisor
Check the wire going from the coil to the starter.
Also, when did you test the furel pressure>?
With the engine off and the key set to on?
are you still there blazerLT
Old 01-09-2005, 08:23 PM
Yes
Old 01-09-2005, 08:27 PM
When i try to start it, it makes a plup noise out the tail pipe and when i stop it wants to turn backwards one time.
