Old 01-09-2005, 08:45 AM
pbond13 pbond13 is offline
Help with suburban
I just picked up a 99 suburban LT. I installed my Kenwood deck and only get sound from passenger side of vehicle. Stock unit did same later on. I took out a Clarion CD changer, could this be it? Is it the stock amp? Where is amp? What would be my best option for good sound without lots of cash at this point? Thanks, Pat.
Old 01-12-2005, 01:31 AM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
Re: Help with suburban
just check all your wires. Something is probably disconnected.
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
Old 01-12-2005, 02:03 AM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
your speakers are probabl blown since you said the some problems occurs with a different unit, you'll most likely need to replace, but to make sure you can test the speakers using a multimeter and checking the impedance. If it doesn't read or reads 0 or something they are blown, If it reads 2,4,6,8 or something your good to go with those speakers and you'll need to troubleshoot in a different are like a factory amplifier if there is one. If that's good then I would check all the wiring and make sure there isn't a short somewhere.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
