Jeep Wont Start
I Went To Town In My 95 Jeep Grand Cherokee Ran Fine On The Way To Town, But On The Way Back It Started Cutting Out, The Next Morning I Started It And It Ran For 5 Minutes And Died, Since Then I Have Not Been Able To Get It Started, What Could Possibley Be The Problem
Re: Jeep Wont Start
Is it turning over (starter engaged) or is it completely dead - no power at all, no lights, etc.?
Re: Jeep Wont Start
It Turns Over And Every Once In Awhile It Will Start But Only For 5 Seconds Then It Dies Again
Re: Jeep Wont Start
could be a couple things bad Fuel Pump, CPS.
when it dies does the CHECK ENGINE light come on when you try to start the jeep? If so, is the Fuel Pump kicking on when you turn the key? - you may have to take the cap off and and listen at the filler neck to hear the fuel pump (whirring sound) |
Re: Jeep Wont Start
The Check Engine Light Comes On Before I Try To Start The Engine But It Does Not Come On After That.
Re: Jeep Wont Start
so when the engine shutsdown, right after that you try to start it and the CHECK ENGINE light comes on but still won't start. Is that what your saying?
jeep won't start
I had similar problems with my 96 grand cherokee see my post "starting problems, no fault codes"
I hope this sheds some light on your problem Tim |
