Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 01-08-2005, 10:24 PM
njkid njkid is offline
Which way is off?
1993 RX7. I cannot loosen the lock bolt off the front of the eccentric shaft that the spring and pellet sit behind. The bolt also holds the hub on that a pulley attaches to. Does the bolt turn CCW or CW. I am using a 1/2 inch Air Gun with a 19mm socket. Also tried a breaker bar. Seems its on mighty tight! I am stuck at this point on my rebuild. Thanks!!
Old 01-09-2005, 12:46 AM
DevoutWankelist's Avatar
DevoutWankelist DevoutWankelist is offline
Send a message via ICQ to DevoutWankelist Send a message via AIM to DevoutWankelist
Re: Which way is off?
clockwise
BAH!, went to change my sig and forgot what I was supposed to put here. . .
Old 01-09-2005, 04:59 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
ive been able to do it with the same equipment on my 12as and s5 13bs
try harder, lol
Old 01-09-2005, 08:42 PM
Now that I know which way to turn it, I will try again. I was trying to go CCW most of the time! Now I know better!
Thanks
Old 01-10-2005, 01:12 AM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Is the motor in the car? did you support the clutch assy? If not, congrats.. Your Torrington bearing just fell..
1988 10th AE Edition TII
More mods then you have.
Old 01-10-2005, 07:43 PM
No J-Rat, the motor is out and down to the bare block on my work bench. Believe it or not every thing has been pretty smooth up until this point. We are ready to start tearing the motor down for the rebuild!
Old 01-11-2005, 01:34 AM
J-Rat's Avatar
Cool! I hate to hear when people take that bolt off and the T-Bearing drops!
Old 01-16-2005, 10:28 PM
Just an update on getting the lock bolt off the front of the eccentric shaft. After beating my brains out trying to get it off in the clockwise direction as I was told by someone who I thought knew what they were talking about. IT IS NOT CLOCKWISE! In the future if anyone is taking it off, please go counter clockwise, it works much better. It might be tough, but once your going in the right direction and give it all you have, it will break loose! Goes to show you, don't believe everything you read, ask a few more people. I learned the hard way.
