Old 03-09-2002, 12:26 AM
patate's Avatar
patate patate is offline
Unhappy paint stripping
Ihave one of my friend model (revell integra) Itry to strip the paint with everything I found from oven cleaner to pine-sol and it doesnt work
the model as maybe 3 coats of testor primer and maybe 6 0r 7 coats of motomaster paint.
What can I do
Please help me
Old 03-09-2002, 12:37 AM
JE123's Avatar
JE123 JE123 is offline
Do they have Castrol Super Clean where you live? It works great and highly recommend it. Just make sure you where gloves when you use it.
-Joshua
Old 03-09-2002, 12:42 AM
patate's Avatar
paint stripping
I live in quebec and castrol super clean is available at canadian tire (its the only place I now they sell that) but i dont know how to work with this stuff.
Old 03-09-2002, 12:55 AM
JE123's Avatar
You first put the Super Clean in a plastic container. Make sure it is large enough so the model will fit in it. Then just put the pieces in it and let them soak for about 2 or 3 hours. After that you should be able to remove some of the paint. I found that a toothbrush makes it easier. You might have to let it soak in the cleaner for a few more hours, because it might not come completely off.
I have left a model in the Castrol Super Clean for 4 days and had no damage to the plastic. So you don't have to worry about that. Just make sure you wear gloves, and work in a ventilated area.
-Joshua
