Old 01-08-2005, 07:44 PM
rodknock rodknock is offline
Send a message via AIM to rodknock
2g pipe in a 1g
I bought a 2g apexi 3" down pipe for 50 bucks from a local dude. The deal sounded good and worst case, i sell it. The question is whether or not anyone thinks the pipe will fit in my 1g awd its for a 2g awd.
90/Talon TSI AWD/Manual
^^^^In most cases I am not a conformist, but I'm sick of the open ended questions as well.
Old 01-08-2005, 07:46 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
Re: 2g pipe in a 1g
dude why would you buy somthing befor finding out if it fits or not?
Old 01-08-2005, 11:38 PM
Re: 2g pipe in a 1g
50 bucks is 50 bucks especially when i can sell it for more. Besides why would you ask the money didnt come out of your pocket?
Old 01-10-2005, 02:55 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 2g pipe in a 1g
Your sig picture is too big, please adjust accordingly I'll be trying the same thing soon, let me know if it works. IF not I Can just cut and reweld, but I would be happy if they are close enough. I'm fairly certain it will not line up with the catback though, I know the angles on that are quite different. So you may be screwed.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-10-2005, 03:12 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Re: 2g pipe in a 1g
Cant believe I missed this thread.
Anyways, the flanges are off/angled differently. If you plan to run a home made bolt up test pipe or a welded up test pipe you will be fine seeing you can rotated the flange as needed. Otherwise you must cut the flange off and weld it back on in the right angle.
This goes the same for GST/GSX downpipes... They are mostly all the same just different angles on the flange to the cat. I have seen a couple that have a different bend but other than that they meet up the same, just need to rotate that flange!
Old 01-10-2005, 08:58 PM
Re: 2g pipe in a 1g
Sorry about the signature just got a camera and got a little trigger happy lol. Thanks for the input though, as you can see i have plenty of work on my hands as is. It will be a while till I break out the welder and the hacksaw. I did a little test fit tonight and it appears that the pipe is longer as well. Side by side the 3" comes to about the middle of the cat but the bends as well as the mounts apear to match up I guess the only problem is that flange then. 2 melted pistons and a cracked turbine housing, gotta love it. Thanx
