Old 01-08-2005, 08:03 PM
brass_monkey93 brass_monkey93 is offline
Brake Squeal
Since I have replaced my brakes with the top of the line pads and rotors from NAPA my brakes have squealed. I have shaved down my rotors and cleaned the pads and I still get the squeal. I have heard that the top of the line pads are made of material which is packed together tighter so that can make the squeal. I am thinking of buying cheap pads from Autozone to see if the lower end pads fix the problem. I'm just looking to see what other peoples opinions are.
Old 01-08-2005, 08:09 PM
CreepingDeath94 CreepingDeath94 is offline
Re: Brake Squeal
If they are metallic pads, they will probably squeel. Also, you have to put the anti-squeel stuff that comes with the pads on the back of the pad lining to reduce that squeel as well. Hope that helps some.
Old 01-08-2005, 08:32 PM
Re: Brake Squeal
thanks for the info, it helps a lot
