Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 01-08-2005, 07:11 PM
prginocx prginocx is offline
1989 Olds 98 Heater issue
Can't seem to get much heat out of this beast. Either in Auto mode with the temp set point at 85 degrees, or in manual mode with heat turned full on...For some reason the air coming out is only luke warm no matter how long the car warms up.
Car has 3.8L V6, 4spd automatic, and automatic climate control system. The only really wierd thing I've noticed is sometimes you are cruising on the freeway, heater putting out strong airflow, but weak heating energy. Then y ou get off and park, but while you are idling all of the sudden the heat is very warm. I can't fathom why the heater would work better at idle than at cruise speed.
Old 01-10-2005, 09:54 PM
1990TS 1990TS is offline
Re: 1989 Olds 98 Heater issue
Have you checked your coolant level in the radiator lately? Wait till system is stone cold before removing the cap. Sounds like system is low and maybe has an air pocket.
Old 01-11-2005, 12:58 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
My brother's olds 88 had the same problem. He replaced his thermostat and it fixed the problem. It's a cheap part to replace first off
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 01-23-2005, 11:23 PM
back2life's Avatar
back2life back2life is offline
Well What Was The Outcome?
Old 03-20-2005, 07:03 PM
Olds98 Olds98 is offline
Sounds like the thermostat. My '90 had the exact same problem, and a new part fixed it right up and improved the fuel economy markedly.
