Old 01-08-2005, 03:19 PM
fritcr's Avatar
fritcr fritcr is offline
97 Mitzi Eclipse Radio code???
My sister bought this car and it was a repo from the bank. Unfortunatily it has a code set in the factory radio and we don't know what that code is. Does anyone know of a way to get that and make the radio work?
Rob
Old 01-08-2005, 03:34 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
you can take it to a Mitsu dealership and they can reset it for you
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 01-08-2005, 04:08 PM
GSXmark86 GSXmark86 is offline
Send a message via MSN to GSXmark86
Re: 97 Mitzi Eclipse Radio code???
to get the code you have to go to a mitsubishi dealer and get it. Some charge you for it, some don't. i know my first one was free at a st. louis dealership, but that radio quit and my second one cost 5 bucks in springfield, so i gues it all depends on where you go. You are better off to have the radio out before you go because they will probably charge if they take it out for you.
Old 01-08-2005, 04:48 PM
CBURKE's Avatar
CBURKE CBURKE is offline
or look inside your owners manual, mine was in there
Old 01-08-2005, 05:00 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
most of the time the codes come from the factory as 1234 ect unless the person who owned it before changes it
Old 01-08-2005, 05:41 PM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
get the serial number on top of the radio and call a Mitsu dealership. they'll ask you for that number and maybe ur VIN number, i forgot if they asked me for that or not
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 01-08-2005, 06:27 PM
george536's Avatar
george536 george536 is offline
just go and dont pay, because theyll try to sucker you into paying.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 01-08-2005, 06:55 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Try 6778. Thats one of the universal codes for the CD player. You only have 3 chances to get it right. After that you must put the battery charger (with the battery connected to the car) on the battery and the key needs to be in the "on" position. You must leave it that way for atleast 1hr and that will reset the CD player.
Old 01-08-2005, 08:15 PM
1trickedoutdsmra 1trickedoutdsmra is offline
Send a message via AIM to 1trickedoutdsmra
why not buy a new cd deck instead of taking it to the dealership and charging you up the ass
Old 01-08-2005, 08:23 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
mine was different but they should be a little piece of paper on top of the radio if you pull it out. try that number and if not call the mitsu place with the id number and they can give it to you over the phone
Old 01-09-2005, 01:48 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
I don't think that they can give you the code unless you go to the dealership...some antitheft deal. But i agree w/ 1trickedoutdsmra i think you should just buy and install a new one, because it would be cheaper than having the dealership do it.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-09-2005, 02:11 PM
Turbo makes me emo!
yea man all i did was call a dealership and gave them my serial number on top of my cd player and that was it. also, when i was puttin in codes at random tryin to figure it out, all i had to do was disconnect and reconnect the negative battery cable for the cd player to reset itself.
Old 01-09-2005, 10:29 PM
shit your lucky mine didnt do that i had to wait 45 min with the key in the acc postion. I stuck a cd in and then it gave me the option of putting in the code
Old 01-09-2005, 10:42 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
if you call the dealership and give them the serial number off the top of the cd player and the vin on your car they will give you the number. if they want to charge you for it call a different mitsu dealership. search google and you can find phone numbers for a bunch of them
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-10-2005, 07:11 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Search the forum.. I posted a dealer that will give out the code with just the serial number
For Sale 98 Eclipse GS, 5 spd
