Old 01-08-2005, 01:04 PM
Lasertime Lasertime is offline
Banned
Engine Swap "Sort of"
Ok heres another one for you guys to chew on. What would it take to stick a 2.4 in a car that has a 2.2. besides money or course. I know the motor mouts would need to be changed and the computer system. and i think the tranny should mount up not sure though. Any advice or heard of this before
Old 01-08-2005, 02:25 PM
noshun's Avatar
noshun noshun is offline
Re: Engine Swap "Sort of"
What a cavalier? It should go in as easy as it can do. you'd need the ECM and the harness and probably have to modify the fuel system, pum etc. I'd also want to ugrade the suspension and brakes
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-08-2005, 02:56 PM
godenm's Avatar
godenm godenm is offline
Re: Engine Swap
the trannys arent the same. as for what you will need to get started: 2.4 engine/trans,axles for 2.4,ecu and harness,fuel lines in engine compartment will have to be modded (but pump should work though),exhaust (from manifold to cat),and mounts.that should get you started.
Old 01-08-2005, 02:59 PM
noshun's Avatar
Re: Re: Engine Swap
What he said!
