Go Back   Automotive Forums Car Chat > Cars in General
Old 01-08-2005, 12:51 PM
Kid_Buick_98&84's Avatar
Kid_Buick_98&84 Kid_Buick_98&84 is offline
Send a message via MSN to Kid_Buick_98&84 Send a message via Yahoo to Kid_Buick_98&84 Send a message via Skype™ to Kid_Buick_98&84
Cool Another Battery
Hello,
I was wondering if i can put another battery ...say in my trunk..to run most of my neons off of. and if so can i just put it in there or what...any help would be much appreciated
Thanks
Fuel For The Soul
- The Red Dragon
2005 Pontiac Grand Am
- The Beast
1987 GMC Rally STX G2500
R.I.P. Pontiac 1926-2010
You Will Be Forever Missed, And Never Forgotten.
Check it out at my Cardomain Page below
http://www.cardomain.com/ride/2176213
Old 01-13-2005, 07:23 PM
Re: Another Battery
...again ANY help would be appreciated....
Fuel For The Soul
- The Red Dragon
- The Beast
Old 01-14-2005, 01:10 AM
MadMac56's Avatar
MadMac56 MadMac56 is offline
Re: Another Battery
I suppose ya could...course you'd have to charge it a lot...might be better to upgrade to a more powerful alternator/battery combination up front...
Just my
Old 01-14-2005, 08:36 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: Another Battery
I agree with madmac , also I am looking into a secondary battery , theres a small box that you can use inline that will keep the new battery from interfering with the charging system by using power from the battery only. Ill find out what is all needed today at work cus like I said Im doing the same for a sterio application. Your neons are suck low power (amps) it shouldnt have that much affect on your charge system and battery and if it is then you must have some problems to look into. Most neon arrangements are hard wireable or fuse holder friendly for power sources. Im not a tec so ask one they should be very helpfull.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 02-24-2005, 05:08 PM
hjthoer hjthoer is offline
surely if you had room under the bonnet you could hook up 2 batteries and run everything off them and they will both get charged if u no wat i mean?
Old 03-16-2005, 11:43 PM
dice daniels dice daniels is offline
Re: Another Battery
first off you'll need to upgrade your alternator to a stronger one. That should be enough.
But if you do still feel you need a battery in your trunk you'll have to run atleist a 4 gauge wire from the positive post of the battery under the hood through the inside of the car to the trunk and connect it to the positive post on your new battery. then you'll need another 4 gauge wire running from the negitve post of the battery to the body of your car. and then you will also need to use two 125 amp fuses. You'll need one as close to the positive posts on each battery as you can get. that way if the wire some how gets shorted you wont have a fire.
And while you're at it you might as well invest in some car audio equipment since you'll have pleanty of power.
Old 04-04-2005, 10:54 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: Another Battery
just get a yellow top battery, everything will be fine and you want have this ugly, in the way battery in your trunk.
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 04-06-2005, 12:27 AM
mysatilac's Avatar
mysatilac mysatilac is offline
not to mention all the wiring you then wont have to do.-Although if you already have at least 4 gauge run for your system you can use this for the battery, and you'll only have to run wire from your system to your new battery, all in trunk, this is a good idea, but its not needed most of the time
My buddy is about to upgrade his battery to a yellow cap, already has a six pack gel battery, already has a 2 ferad cap., and already beefed up his alternator, none of which helped him at idle-his battery gauge plumets when he stops at a red light, because of his huge system (let alone when he turns on his neons/headlights/rolls down his windows/etc.)...
his windows roll down s l o w,
If the Yellow Top battery doesn't help him (I'm sure it will) I will suggest this to him.
It's beautifully destructive isn't it,
'97 Maroon SL1- Bored Throttle Body, Knife Edged Throttle Plate, Short Ram Intake 3" Cone Filter, Flip Flop Trunk, Red Enameled Engine, Interior & Exterior Painting Mods, 4" Burnt Tip Muffler, DRLs ON A SWITCH!, "Rims", Seat Covers, And A Stereo System Thats Too Good!, Other various mods and detailing...
