Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-08-2005, 12:58 PM
sprayedlude93 sprayedlude93 is offline
Send a message via AIM to sprayedlude93
how to get the bleed the clutch?
i have a 4th gen lude that i did a h23 to h22 swap on and the clutch is to the floor. how do i correct this., any sites or step by steps? thanks
Old 01-08-2005, 10:09 PM
mofoism mofoism is offline
Re: how to get the bleed the clutch?
You have to find your slave cylinger, usually located near the front, by the clutch. I've done this on my bro's 89 lude. There is a little bolt that must be loosened which is the bleed bolt. Loosen it but don't take it out. Now pump the clutch while someone else pours brake/clutch fluid into the master cylinder. Be careful that the master cylinder doesn't go empty...if you pump it while it's empty, air will get into the lines and you'll have to pump it through and start all over again. Once it gets to the point that your clutch is tight (raising up off the floor by itself), tighten down the bleed bolt and continue pumping until it is back to normal. Adjusting may be necessary on the clutch to get it to the correct height (look in your owners manual)
