Old 01-08-2005, 11:16 AM
97blazermadness 97blazermadness is offline
Drain the pumpkin
Gonna drain and fill the pumpkin today. Any problems or issues with getting the cover off without removing the sway bar? I should be able to do this without removing the sway bar right?
Thanks!
Old 01-08-2005, 11:41 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Drain the pumpkin
Is the gasket leaking? If not... it would be easier to use a pump in the fill hole.
To answer your question...the sway bar shouldn't be a problem.
Old 01-08-2005, 09:51 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Pump in the fill hole would be a lot better.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-08-2005, 10:21 PM
crazys182003's Avatar
crazys182003 crazys182003 is offline
I got a dumb question........What is "the pumpkin"? is that what you call your truck or is it actually something slang for something else?
Old 01-08-2005, 10:25 PM
swalt's Avatar
swalt swalt is offline
Re: Re: Drain the pumpkin
I hadn't heard the term either, but based on the description, it is the rear axle case. They don't put a drain bolt in it, just a fill bolt, so to drain it you either pump it out or pull the cover and replace the gasket.
Old 01-08-2005, 10:33 PM
oh ok so I take it the part most likely looks like a pumpkin. Well when my truck needs attention there I think I will opt to go to a shop. draining thigns with drain bolts is so much easier.
Old 01-09-2005, 06:01 AM
blazee's Avatar
Problem?
Re: Re: Re: Drain the pumpkin
Yeah, we're talking about the rear differential.
Old 01-09-2005, 06:04 AM
blazee's Avatar
Problem?
If you have a 4wd drive you are better off buying a pump, because that is the only way to change the fluid in the front diff., it doesn't have a drain plug or removable plate.
Old 01-09-2005, 12:48 PM
BlazerLT's Avatar
AF -Advisor
Yea, a hand pump is really cheap.
Old 01-10-2005, 10:49 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
I ghettoed mine together using aquarium tubing and a turkey baster. Takes a bit more time, but you will get it dry. Fish the tubing around and just keep sucking up the oil until you can't get any more...then refill. The same baster works for refilling too.
Old 01-10-2005, 12:18 PM
blazee's Avatar
Problem?
I bet your wife loved that. I hope you told her before Thanksgiving.
Old 01-10-2005, 12:39 PM
wolfox's Avatar
Nope, not a problem there. See, I am single....
And now you know one of the reasons why. Anything left idle in the kitchen is a potential tool.
Old 01-10-2005, 12:57 PM
blazee's Avatar
Problem?
Hey, whatever works. Potential tools are only limited by your imagination.
Old 01-31-2005, 10:24 AM
Just an update: I got to this job over the weekend and wasn't bad at all:
Removed the rear axle housing cover and gasket -- have a drain pan handy, it all runs out. The cover slid right out between the sway bar so that wasn't an issue at all.
Cleaned the gasket surfaces real good and re-installed the cover.
Refilled with Valvoline 75W-90 Synthetic.
Old 01-31-2005, 10:51 AM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
What kind of pump
I am interested in changing both front and rear differential fluids as well, but what kind of pump are you talking about.? Is there something commerically available specific for this task...
Help is appreciated !
thanks
Tony
