Old 01-08-2005, 10:45 AM
MadKiddJack MadKiddJack is offline
heater not heating
does anyone have any suggestions of what I can check to find out why my heater blows cool air?
Old 01-08-2005, 11:27 AM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: heater not heating
Whenever I pull my climate controls out, the little cable under behind the center console, under the dash comes loose off the heater control arm and just moves freely back and forth. Look under there and move the temperature knob back and forth and if you see the little metal cable moving back and forth with out being grabbed on anything. If so, move the cable and hook it back up to the heater control arm.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 01-08-2005, 11:34 AM
Canabalooza Canabalooza is offline
That cable btw hooks up to a little box and controll arm in the middle of the firewall right behind the center console on the dash. move the knob and check to see if thats moving also. also check the valve in the engine compartment. its located on the left side if you looking at the front of the car on top of a small black radiator hose. if both move it might be your heater core. mine wouldent heat and the vavle in the engine compartment moved but the black cable on the climate controlls broke and wouldent let the hot air into my car. Good luck. Its freezing outside.
P.S ill go snap a quick pic and post them here in a min.
Old 01-08-2005, 11:51 AM
2CrX's Avatar
2CrX 2CrX is offline
If its the heater core, have fun replacing it.
Old 01-08-2005, 12:20 PM
i took a couple of shots of the valve that I belive you are talking about. If I need a new heater core what do you think of one from a junk yard?
Old 01-08-2005, 12:52 PM
Shaguar47's Avatar
Then if everything, linkage wise is working, looks like your gonna need a new heater core.
Old 01-08-2005, 01:11 PM
k thats the one that is under the hood mine was working like that too thats fine. but the one inside the car looks like this sorry for the delay.
look for the little black cable and turn the part its attached to also check to make sure the dial for the heat/cool turns the one inside.
Old 01-08-2005, 01:29 PM
my inside one wasn't moving with the cable. I manually moved it and I got heat thanks for the help.
Old 01-09-2005, 12:50 AM
arodg25's Avatar
arodg25 arodg25 is offline
it could just be something stupid. have you checked you coolant level? probubly have but you never know
Old 01-09-2005, 01:27 AM
]{iwi's Avatar
]{iwi ]{iwi is offline
Registered User
Send a message via MSN to ]{iwi
l0l
