Go Back   Automotive Forums Car Chat > Renault > Clio/Clio II/Clio III
Old 01-08-2005, 04:30 AM
cooperman cooperman is offline
Question Clio Starting Problems
Help, please
My son's Clio 1.2 16v dynamique will not start. The starter solenoid clicks, but the motor does not spin. The motor has been tested off the car and works fine. All electrical connections, earth and battery are perfect. the fuel pump starts when the ignition is switched on. All electrics (doors,windows etc work OK when ignition is switched on). Could it be the immobiliser as I have heard that these can be probelmatic
thanks in advance.
Old 02-11-2005, 05:22 PM
mark carroll mark carroll is offline
Send a message via MSN to mark carroll
Re: Clio Starting Problems
in what way did you test the starter motor?does it make any attempt to turn the engine?
check when you turn the key in the ignition that the red light on the dash dissapears as if it stays on this will indicate an immobiliser fault/activated
Old 02-12-2005, 02:13 AM
Re: Re: Clio Starting Problems
Ok. Took motor off car and stood it on bench. Connected battery to terminals, turns OK.
Immobiliser light stayed "on" when ignition swithed on. Since battery has been changed, it now goes out.
Has been starting OK ever since
Old 02-12-2005, 11:36 AM
ok glad you got it sorted.hope renault coughed up for the battery i would expect at least 60k out of one.
