Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-08-2005, 01:04 AM
adamgtx adamgtx is offline
4g63 Swap
will be putting in a 4g63 from japan in 94 eclipse thats 4g63 is blown both are na (just need it to get around) what r the differences if any? and how hard would be the swap?
Old 01-08-2005, 02:12 AM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
Re: 4g63 Swap
the ecu is different
Old 01-08-2005, 11:39 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: 4g63 Swap
i am swaping a 4g63t right now. the big difference is if there are awd and fwd differences. if so, then you will have flywheel issues. as well, the ecu should be fine. i know a few guys who have done the same swap and they used their old ecu. as of now, that is all i really know of.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-07-2005, 02:48 PM
blue94eagletalon blue94eagletalon is offline
Re: 4g63 Swap
my friend put a jdm 4g63 in his car which has a 4g63 and it bolted up and worked just fine without any trouble with the ecu
Old 02-07-2005, 04:44 PM
bighauns's Avatar
Re: 4g63 Swap
The ECU is only a big deal when you use the JDM intake manifold I think. As well you will want it if the engine comes with larger injectors. That is my understanding though, I am not totally 100% sure if that is accurate, but reasonably so.
Old 02-07-2005, 05:01 PM
GotGrip666's Avatar
Banned
Re: Re: 4g63 Swap
are you trying to say your friend put in a jdm 4g63 with the usdm ecu with no problem?
Old 02-07-2005, 08:33 PM
Str8in Str8in is offline
Banned
Send a message via AIM to Str8in
Re: Re: 4g63 Swap
Thats not an issue all you have to do is use a FWD flywheel if it comes with a awd flywheel and vise versa
Old 02-10-2005, 12:49 PM
Re: 4g63 Swap
yes the jdm 4g63 started on the first crank. all we did was put the motor in and plug it in
Old 02-14-2005, 07:29 PM
bighauns's Avatar
Re: 4g63 Swap
Was it the Cyclone intake Manifold? What about the injectors? It all depends on a few different variables. there is a chance that it could start up right away, but then your fuel mileage could be affected.
Old 02-15-2005, 11:34 PM
Fast Forward Fast Forward is offline
Re: 4g63 Swap
Just in case you need a source.
www.jdm-motor-engines.com
Old 03-02-2005, 10:09 AM
no it wasn't a cyclone
Old 03-03-2005, 09:27 PM
matth matth is offline
Re: 4g63 Swap
I just finished a swap from a 1.8 to a jdm 6 bolt 4g63 used everthing that came with the engine. Bought a usdm ecm and usdm wiring harnes and had no problem at all so you should have no problems going from a usdm to a jdm .
Old 03-03-2005, 09:34 PM
Re: 4g63 Swap
I know of a pretty cheap place to get a jdm 4g63 try soko.com. I got mine thier for $490. shipped
Old 03-04-2005, 07:57 PM
Jroc97 Jroc97 is offline
Thnx alot for tht site bro, I think ima work with them.
97spyderGS
