2002 Odyssey Key Fob Progamming
Does anyone know to program a key fob for a 2002 Odyssey EX with the power sliding doors. I have an extra remote but it does not work and I want to try and program it myself to save the dealers charge.
Thanks Jason Gvillejb |
not working
The thread down below contains the info but for some reason I cannot pull it up so if someone has another program sheet I would appreciate it very much.
Thanks Jason |
Re: 2002 Odyssey Key Fob Progamming
I have
Hey I looked around and this is what I could find for an odyssey, hope it helps.
NOTES: - For steps 2 through 12 below, each step must be completed within 5 seconds. For step 13, within 10 seconds for each remote. - Up to four remotes can be stored in memory. - All remotes to be programmed must be on hand. - A non programmed remote will work for this procedure. - Turn the ignition key to the OFF position to complete the programming procedure. STEPS: 1. Disarm the security system. 2. Turn the ignition key to the ON position. 3. Press the LOCK or UNLOCK button on the remote control transmitter. 4. Turn the ignition key to the OFF position. 5. Turn the ignition key to the ON position. 6. Press the LOCK or UNLOCK button on the remote control transmitter. 7. Turn the ignition key to the OFF position. 8. Turn the ignition key to the ON position. 9. Press the LOCK or UNLOCK button on the remote control transmitter. 10. Turn the ignition key to the OFF position. 11. Turn the ignition key to the ON position. 12. Press the LOCK or UNLOCK button on the remote control transmitter. - The power door locks cycle to indicate programming mode. - The Status LED illuminates simultaneously for 1 second. - To terminate the programming mode at this point, either turn the ignition key to the OFF position or leave the remote's button untouched for over 10 seconds. To program the remote, perform steps 2 through 12. 13. Press the LOCK button of each remote (one at a time) to be stored in memory. - The power door locks cycle to confirm each entry. - The Status LED illuminates simultaneously for 1 second. - A button on each remote control transmitter to be programmed must be pressed. Perform the programming step within 10 seconds for each remote or else the programming mode will terminate. |
does anyone knows how to disarm the security sistem for my 2000 honda odyssey ex
