Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 01-07-2005, 10:13 PM
gpshslax gpshslax is offline
Trunk Release and parking light wiring / dashboard construction
I'm in the process of installing an aftermarket remote wireless kit in my '99 sable. I know that everyone says that they all came with one, but I tried that "turn it off and on 10 times" thing and nothing happened. In any case I've already hooked up the power wiring and the the door locks from my kit, and they work fine. My problem is now with hooking up the trunk release and the parking light conformation.
I know which wires I'm supposed to splice into but they are really inaccesable. The parking lights are located at the the light switch, and the trunk wire at the trunk release button. Additionaly the trunk release wires are bundled in a clear vinyl sheath. With the kick panel out i can see them but I can't immagine being able to work up there. Technitions must be able to remove these parts somehow or at least remove the front of the dash so they are accessable. Anyone know how to do this? Alternatively does anyone know if these wires run somewhere easier to get at? I thought that the parking lamps must run through the fuse box, but I just thought I would ask.
Old 01-11-2005, 04:41 PM
KimMG KimMG is offline
AF - Advisor
Re: Trunk Release and parking light wiring / dashboard construction
Look at your wiring diagram and see where the wires are going. In a repair manual (haynes or some other publisher) look under heater core replacement. You will find the instructions for removing the dash.
