Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 01-07-2005, 08:30 PM
XchiboiX XchiboiX is offline
Send a message via AIM to XchiboiX
Making accent faster????
OK i know this sounds kinda weird but i have a 2003 accent and im jsut a freshman but i do drive it sometimes, but i was planning to modifi the car so it can run faster and better any advice?? =
Old 01-08-2005, 03:03 PM
Tiburon99 Tiburon99 is offline
Re: Making accent faster????
A freshman as in high school? Bcuse if you are, freshman to freshman I would not recomend moding the car to much at our age. And if you were to still mod your car, I would recomend something like a cold air intake to start.
Old 01-10-2005, 02:16 PM
jerzralliart jerzralliart is offline
Send a message via AIM to jerzralliart Send a message via MSN to jerzralliart
well freshman in in h.s or college i would not even waste the money to mod your accent. i had a 01 and did alot of research and there just is not alot of companies out there making things, and for the amount of money you would spend doing would be crazy you could spend the same amount as someone who has a honda,mits,mazda, and you would still not be close to there hp. but if you don't care about that i would just get a cai,downpipe and exhaust, and maybe a 25-50 of nitrious and that's it, and a bigger throttle body
Old 01-10-2005, 03:01 PM
what da you mean not be able to have hp or keep up with a honda. A accent can smoke the s$$$ out of a civic stock. and customized they are just a bit better than a stock tib v6.
Old 01-10-2005, 03:07 PM
Believe me, my father used to own a 01 accent manual trany and when he said hold on that he was going to floor it I was like all whatever this stock 4 banger has jack crap in it. But then he did floor it and when he did, it was like aw s$$$ you just like got sucked back into the seat and everything.
Old 01-10-2005, 07:07 PM
wut bout like something more hardcore like turbo, would that like blow the engine or something?
Old 01-11-2005, 02:39 AM
accent gsi's Avatar
accent gsi accent gsi is offline
Send a message via MSN to accent gsi
try swapping that 1.5 alpha engine to the 2.0 beta engine (elantra 97 or upper). Im in research of that. The beta engine (used in the 1 Gen Tiburon/Coupe) has a lot of mods like a lot of pieces for that engine. However, expect some mistakes and major mods (brakes!, accent sucks during high-speed braking)....
ah, and one special version of the accent with supercharger was made by a dealer in the us, with 115 hp's. Unfortunatly, only 2 were modified...
a four banger with attitude... so bring your V8 and lets see how fast is your dino...
Old 01-12-2005, 01:00 AM
ic, but i was thinking bout keeping the engine stock and jsut tuned the other stuff, anyways will the car accelerate faster if i push it in higher rpms?
Old 01-13-2005, 11:29 PM
accent gsi's Avatar
yap, the accent engine's have a better response at high revs (more than 3,500rpm) Try to feel when the car began to make more sound than movement'... when it's push decrease and sound increase, at that point you should shift.
c ya
Old 02-01-2005, 12:51 AM
an accent beating a civic come on get out of here. i had a 2001 accent 5spd and it only had like 100hp. stop living in your fantasy world.unless you plan on droping major money into your accent like a few thousand dollars. save your money and buy a car that has a better starting point then the accent.
Old 02-01-2005, 12:53 AM
and the engine swap is gonna cost you who knows how much all together maybe like 2000 and just to put yourself at 130-140hp. it's not worth it
Old 02-02-2005, 03:09 PM
KoreanMuscle05 KoreanMuscle05 is offline
you all are forgetting a little something called "power to weight ratio"; sure, the accent has 105bhp stock, but it also weighs 2200lbs. That's going to be even or quicker than a 125bhp car that weighs 2800lbs. so an accent that has 125hp and weighs 2200lbs vs. a car that has 125hp and weighs 2800lbs... who's going to win?
Old 02-03-2005, 10:42 PM
mike5721947 mike5721947 is offline
Send a message via AIM to mike5721947 Send a message via MSN to mike5721947
yes its true for a teen the accent does suck you into the seat but they have major problwms with the tranny (we have a 2001) we have replaced the tranny and the clutch and the clutch is soon to be gone for the second time! by no means is this car driven hard its never been raced or anything, its barily been over the speed limits!
the accents have under 100hp and there is close to no aftermarket for the accent (there are body kits and such but not much) i am soon to be getti g a car and i have been offered the accent and quickly objected to being given it. i would much rather get a civic adn seriously a accent will not beat a civic! (ok well maybe a accent vs a 75 civic with the crappy 1.6)
if anything if you still want to mod the accent you will want to get a intake and exhaust and ignition,plugs,wires
Old 02-04-2005, 12:17 AM
mazdatech mazdatech is offline
I would honestly rate the accent that is made for the U.S. @ 80-90 hp Max. At least that is what I have read in the specs @ work. It aint made to go fast. It is made to be affordable transpo.
Old 02-04-2005, 01:20 AM
although not very reliable
