Old 01-07-2005, 08:28 PM
bd2988 bd2988 is offline
Question Question about fusebox
95 escort lx 1.9l
I recently bought a new cooling fan and I'm trying to troubleshoot to get it running. Thing is, I'm not sure what this one object is. It's located in the main fuse box in the engine compartment. It's labled COOLING FAN. I know there is also a COOLING FAN 40A fuse spot, but am just not sure what the object located in COOLING FAN (Black squarelike plug object which has a coil inside of it) is. If someone would please tell me what this is it would be greatly appreciated. Thanks!
Old 01-07-2005, 08:56 PM
A. Souphound A. Souphound is offline
Re: Question about fusebox
I don't have a wiring diagram handy but it sounds like the Cooling Fan Relay.
Alvin
Old 01-07-2005, 09:00 PM
Thanks for posting.... Here's some more info. On the object, it says "H270" DC 12V 20A. Any more ideas?
Old 01-07-2005, 10:03 PM
mlw35405 mlw35405 is offline
It is the cooling fan relay. Pull it out and make sure the 4 wires going to it are getting a good connection-there is a problem with them getting a bad connection and overheating. If you see melted plastic when you pull it out, you've found your problem.
Old 01-08-2005, 12:58 AM
Bingo! thank you, thats it. MELTED PLASTIC.... Geez, why bother getting a manual when you got ppl like yourselves on here!
Wasn't being smart btw, there was really melted plastic and thats the problem, THANKS!
Old 01-08-2005, 01:09 AM
When you put the new relay in, you'll probably want to put new ends on the wires, otherwise you'll have the same problem. Just take your time and make a note of where they go, it can be quite a headache. Glad I could help!
Old 01-08-2005, 01:48 AM
Well, that shouldn't be a problem... But, thing is, I don't know how much a cooling fan relay costs. Any idea?
Old 01-08-2005, 04:14 AM
Advance Auto Parts can order you one for around 12 bucks, or you can get one from Ford for about 30.
Old 01-08-2005, 07:16 PM
Got one from a junkyard for 5 bucks. I then cleaned the connections and replaced it, and then presto... FAN WORKS! Thanks for the help and info!
