Originally Posted by grasshopper2
I got a 1987 730i se auto, great motor, central locking functions but when I lock it, it opens immediately automatically, I have to lock it again for the doors to remain locked. Why does it open again? can anyone advise how to rectify the irritation?
I have exactly the same problem and know why, so maybe this will help. On my car, a previous owner removed, for whatever reason, the solenoid on the boot lid, effectively removing it from the central locking circuit. This means that the boot has to be opened and locked manually, using the key. The side effect is that when I lock using either the key or the remote, the locks all pop open again,meaning I have to re-lock again,so, I'd check that all solenoids etc, on each door are fully operational, with good connections. I'd check the boot first, as this is the most accessible, and most easily disturbed. The doors will have to have the inner door cards removed to investigate further. I dont imagine its a fuse, as the locks actually operate, which they shouldnt, if this was the case. A bad connection or contact is your most likely cause. Hope this helps.
