Go Back   Automotive Forums Car Chat > Chrysler > PT Cruiser | PT Cruiser Convertible
Old 01-07-2005, 04:28 PM
corvair corvair is offline
timing mark
Is there a timing mark on the flywheel? I could not find one on the crank pully. or is it only checked by the scan tool?
Trying to find TDC.
Old 05-30-2005, 06:06 PM
win_daddy win_daddy is offline
Send a message via Yahoo to win_daddy
Re: timing mark
Trying to find TDC.
Take an old spark plug that fits the engine (or buy just one), break off the ground electrode and attach a 1-1/2" extension to the center electrode (tack welding a piece of welding rod to the center electrode should work). Screw this plug in cylinder #1. Now rotate the engine by hand till it stops (piston hits the extension on the plug). Pick a reference spot on the timing cover and mark the balancer (soap stone works good). Then rotate the other way until it hits again and mark the second spot. Exactly 1/2 way between the two marks will be TDC on #1 cylinder.
