Old 01-07-2005, 02:44 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Question Airbrush Leaking
I have a aztek 7778 airbrush, with no compressor yet, i noticed that everytime i use it with airbrush propellent, the nozzle seems to leak, i tried all the nozzles, airbrush works fine, but it leaks, could it be broken, i mean if i buy a compressor i won't mind cause it'll be free air, but air brush propellant is pretty expensive. I was just wondering if anyone else has this problem, or knows how to solve it. Also once the propellant has been used for a little bit, the leak seems to decrease, with enough pressure for airbrushing, could the propellant have too much pressure for the air brush? Any feedback would be appriciated!
In Progress
Old 01-07-2005, 03:41 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
Re: Airbrush Leaking
Have you used the little wrench to tighten the nozzle? There is a small plastic washer to seat the nozzle and if its not tight it will leak air
Freakin' Groovin"
Old 01-07-2005, 04:49 PM
Verminator's Avatar
Verminator Verminator is offline
Send a message via AIM to Verminator
If your talking about leaking paint then yes I have the same problem if I use it for too long I end up with paint all over my hand, ive tried tightening the end and I even sent it back for testing and repair and they couldnt find a problem either. I think it may be a design problem as I know at least two other people who have the same issue.
Old 01-07-2005, 09:34 PM
MidMazar's Avatar
yeh i tried using the wrench, no it doesnt leak paint, just air
In Progress
Old 01-07-2005, 10:01 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
Guys you really need to stop buying that propellent crap. its $$$$$. next time instead of buying a $10 can of propellent, go buy a $20 airtank and fill it up at the gas station once a week. surely you or your parents go to the gas station once a week right?
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 01-08-2005, 11:56 PM
008's Avatar
008 008 is offline
My Aztek's nozzle never seated against the body since I bought it. It was at least a 1mm gap and I wondered why the heck the gasket was even there. I guess it does leak a very small amount because I see bubbles come out of there when I clean the unit.
-Ron
Old 01-09-2005, 08:46 AM
bvia's Avatar
bvia bvia is offline
Re: Re: Airbrush Leaking
Mine also. Air (not paint) will leak from around the nozzle to body connection. It's readily visible as bubbles when I use Windex to flush out the acrylic paint, but since it hasn't affected my painting I've never worried about it.
hth,
Bill
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
Old 01-09-2005, 08:58 AM
Technoman's Avatar
Technoman Technoman is offline
Mine doesn't seat fully either but I have never had problems with it leaking air. I have the metal body version.
Old 01-09-2005, 10:55 AM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
I've gone through three Aztec/Model Master airbrushes in the last three years or so because of the air leaking problem in the valve. I noticed air also leaks from the nozzle area too, like BVIA mentions, but it has not effected the painting. I called Aztek and was told they will only replace airbrushes that have a lifetime warranty on them. The Model Master airbrush I had didnt have this warranty, but they were nice enough to replace it one time. I have come to the conclusion that if you do some serious regular airbrushing, its worth spending extra money and getting an all metal one that can be completely disassembled and rebuilt. Good luck with resolving your problem.
Old 01-09-2005, 11:08 AM
Vric's Avatar
Vric Vric is offline
Considering that those "high end" Aztek are same price if not more expensive than any good Metal Badger, Iwata or Paasche airbrush, that come to the same conclusion than before: Aztek are overpriced toys..
Old 01-09-2005, 10:52 PM
008's Avatar
008 008 is offline
Re: Re: Re: Airbrush Leaking
I bought one when they first came out, around 1996, when they were still labeled as Model Master. Later I heard a lot of fuss over this "Aztec" and realized it's the same thing that I had, although I figured they probably fixed a lot of the problems it had back then. Apparently not.
The leaking never bothered me either but I was worried at first since I figured there must be a reason they put a washer there. I don't think mine leaked paint although I'm so messy I probably didn't notice it.
I can't complain too much about it since it still works, even with the original three nozzles it came with. Since I acquired a Badger 175T I've only been using the aztec/MM for detail painting and it does the job.
Old 01-10-2005, 05:56 AM
Martbee Martbee is offline
I won't comment again on Aztec... already did a lot of time (use the search tool to understand what I'm saying) but, I'll comment on the propellant can thing... STOP WASTING !!! It's a big white elephant... Try to find something else to spray your paint... compressor or a spare tire or a anything but stop the can... please. Stay with Aztec if you want but drop the can. It's a big waste of time, moneyssss and do a lot of garbage.
